Thread: window mist/ front carpet wet
Results 1 to 10 of 10
  1. window mist/ front carpet wet
    Mar 2008
    Recently, when i step into the car in the mornings ive noticed the windows are a bit misty. so i checked over the plenum chamber, this was dry.
    only this morning, i noticed under the driver front and some of the rear driver side carpet was completely drenched.
    now i am aware that the ccm is on the passenger side, so how does the water get on to the driver side carpets?
    how would i go about resolving this?
    Thanks.
    b5.5 1.8T Sport (2001)
  2. Re: window mist/ front carpet wet
    Norfolk
    Did you check plenum chamber drivers side?.
    Also check air con drain pipe isn't draining into the car.
    Door seal, especially the armour plate behid the door trim. often leak water after rain.
    Good luck.
  3. Re: window mist/ front carpet wet
    Mar 2008
    There was water on the driver side but not in the plenum chamber i.e where the battery is, but there was on the far left. is the are you are referring to?
    how do i access the aircon drain pipe, where is this?
  4. Re: window mist/ front carpet wet
    Norfolk
    I mean where the servo is. The aircon drain runs down the center of the dash board area at the back and goes out through a hole at the bottom. This usually leaves a little pool under the middle of the car when the aircon is on in the summer, assuming the pipe is in the right place. My money is on a door/door seal leak.
  5. Re: window mist/ front carpet wet
    Chipped2 Guest
    My 2002 Passat had water in offside rear passenger carpet from a leaking ECU seal in the plenum chamber that didn't wet the drivers carpet but passed beneath it. It was done under warranty.... as was the pollen filter housing seal and I believe the bonnet cable grommet as it passes through the bulkhead (a common leakage point on various models of Golf too).
    All were done in 2004 and have remained dry. New carpets were also fitted. The above leakage points are more common I believe than door seals/door 'card' seals which on my three Passats have all stood up to a combined mileage of 500k+. They are still in the family.
    It is still necessary to clear Plenum chamber drain holes at least annually and avoid parking beneath trees if at all possible.
  6. Re: window mist/ front carpet wet
    Sep 2008
    One by one, all of my doors developed leaks.
    Try parking the car with the suspect side up on the kerb, and check for leaks. In heavy rain i could sit in the car and see it trickle in over the plastic side trim at the edge of the carpet.(2003 B5.5)
  7. Re: window mist/ front carpet wet
    Chipped2 Guest
    I am not suggesting that the following has any bearing on your problems with your door seal leakage, but having had three children I never allowed them or their friends to slam the car doors, which must have an effect on the door seals life. Slamming doors must be equally detrimental to the electronics/circuit boards within the doors too.
    Parking the car 'uphill' certainly increases the possibility of water pouring over the pollen filter itself if the drain holes are partially blocked preventing that sudden downpour from draining away as quickly.
  8. Re: window mist/ front carpet wet
    Most likely cause is water getting in through the pollen filter housing. They have a gasket/seal which perishes over time, allowing the water to lterally pour into the car on the passenger side - soaking the front & rear floor.
    There was a recall for this see:
    http://i228.photobucket.com/albums/e...l/DSC00542.jpg
    http://i228.photobucket.com/albums/e...l/DSC00544.jpg
    My 2002 Passat flooded due to the above, I was told that there was no outstanding recalls on my car so I got a local VW specialist to remove and refit the pollen filter housing.
    I managed to prop up the carpets to allow them to dry out (took weeks).
    The above issue is well documented on the variuos VW forums. You should deal with it before the water overwhelmes the CCM which is under the front passenger seat.
    Good luck!
  9. Re: window mist/ front carpet wet
    Chipped2 Guest
    Pollen filter housing seal only affects the passenger side front and rear.
    Thought the problem was on the drivers side front/rear ?? If so CCM will not be affected.
  10. Re: window mist/ front carpet wet
    Quote Originally Posted by Chipped2 View Post
    Sorry didn't read the OP properly - good luck getting it sorted.
  1. Diagnosis codes, 05 B7 2.0TFSIQ
    By grr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-12-2011, 04:01 PM
  2. Front electric window issue
    By burkey1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-10-2011, 12:02 PM
  3. Please Help Wet Carpet on Passenger Side
    By Tyroaudi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-04-2010, 10:03 AM
  4. Option Codes
    By Samcat in forum Passat - Archive Topics
    Last Post: 23-11-2006, 11:25 AM
