Thread: 2003 A4 2.5 TDI PRND flashing on dash fault code 18201????
Results 1 to 10 of 11
  1. 2003 A4 2.5 TDI PRND flashing on dash fault code 18201????
    Jan 2011
    Manchester
    Hi i have just put vag com on my 2004 A4 2.5tdi triptronic because PRND has started flashing in red on the dash and i dont have any drive until it stops and it came up with fault code 18201? It had a recon gearbox 4 months ago and is still under warrenty but they didnt change the ecu could they of damaged it some how?
    I believe there is a problem with my gearbox ecu and i know a company that will fix it if i send it off to them but i dont know where the ecu is on my car could anyone advise me where its is and have difficult it is to remove?
    Any help appriciated
    Tony
  2. Re: 2003 A4 2.5 TDI PRND flashing on dash fault code 18201????
    May 2009
    maidenhead
    as far as i am aware the ECU is in the gearbox itself.
    hope you get it sorted without too much expense mate
  3. Re: 2003 A4 2.5 TDI PRND flashing on dash fault code 18201????
    Apr 2009
    Somewhere....Over The StrongBow
    Quote Originally Posted by bigtoe22782 View Post
    i dont know where the ecu is on my car could anyone advise me where its is and have difficult it is to remove? Tony
    Its under the drivers seat (rhd)
    Regards
    Jim
  4. Re: 2003 A4 2.5 TDI PRND flashing on dash fault code 18201????
    Jan 2011
    Manchester
    Are you messing with me its under the drivers seat?
  5. Re: 2003 A4 2.5 TDI PRND flashing on dash fault code 18201????
    Apr 2009
    Would i do such a thing? Well yes, but not this time.
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=18083
    Regards
    Jim
  6. Re: 2003 A4 2.5 TDI PRND flashing on dash fault code 18201????
    Feb 2011
    Redditch Worcs
    Hi your gearbox should be a 01j transmission the easy way to tell is look at the gearbox if its all alloy with no sump and a wiring loom going into the back top end of the gearbox then its a 01j and the ecu is inside the transmission. To remove it you need to remove the rear gearbox mount and frame unplug the loom by turning the lever anticlock then remove all the size (45 torx) bolts from the end case and pull the case off note the oil will come out the gearbox. You will then see the ecu its in black plastic. There is 3 size (30 torx) bolts holding it in the gearbox take the 3 bolts out and pull the ecu off but be careful there are long speed sensors on the ecu that can be easy broken hope this helps
  7. Re: 2003 A4 2.5 TDI PRND flashing on dash fault code 18201????
    Apr 2009
    01j is an multitronic box, op'er says he has a triptronic
    Regards
    Jim
  8. Re: 2003 A4 2.5 TDI PRND flashing on dash fault code 18201????
    Feb 2011
    Redditch Worcs
    Yes I know he said he has the tip box but sometimes people get mixed up the tip box will have a sump on it which will be the ZF auto but in 30 years reconditioning automatic transmissions I have not come across an ecu fault with a ZF before so was just posting the info about how to remove the 01j ecu so he can work out which box he has and also will know where both ecu are
  9. Re: 2003 A4 2.5 TDI PRND flashing on dash fault code 18201????
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Another way to determine which box he has is simple
    Front wheel drive = multitronic
    Quattro = tiptronic
    A6 2.4 SE (2000)S3 1.8T (2001)80 Coupe 2.3 (1991)
    A3 1.8T sport (1997)A4 3.0 QST (2002)
    80 Coupe 2.6S (1995)A4 Cab 2.4 sport (2002) Another 2.6 '95 coupe in byzanz purple
    '88 type 89 90 saloon kv 5 pot A4 1.8T 2001
  10. Re: 2003 A4 2.5 TDI PRND flashing on dash fault code 18201????
    Apr 2009
    Quote Originally Posted by fourringsrus View Post
    Quattro = tiptronic
    Correct, and in a previous post Bigtoe22782 said he had
    a Quattro.. https://www.vwaudiforum.co.uk/forum/s...919#post606919
    I looked before i leapt
    Regards
    Jim
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. Esp malfunction/parking brake
    By BIGSSS in forum VCDS - Help Requests
    Last Post: 21-01-2010, 01:52 PM
  3. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  4. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
