Thread: front brakes and discs
Results 1 to 10 of 10
  1. front brakes and discs
    May 2007
    Tamworth Staffs
    Hi, looks like my front discs need changing on my a3 1.9 tdi 130. is it a big job? have located a set of mintex discs and pads for £70. Does anyone know the part number or where I can get it from. Any help would be much appreciated.
    Al
  2. Smile
    West Yorkshire, UK
    Hi I bought my brakes bits from www.gsfcarparts.com but I haven't yet fitted them and have been told that the only way to unwind the calipers is to use a machine that only VW/Audi garages have. Is this true?
    A, A
    Only rears need a piston wind back tool. Not the fronts.
    The brakes are easy, i did all of mine with no previous experience.
    Sourced my rear discs and pads from GSF and the fronts off ebay, inlcuding pads. Total cost including piston wind back tool £170.
    This will help loads:
    http://www.passatworld.com/forums/sh...d.php?t=179518
    Just another B7 Estate
  4. Front discs etc
    May 2007
    Tamworth Staffs
    Thanks for the help, have not done brakes for a long time . They now have ABS and sensors and things!!! so thought it may be a little difficult, the manual says not. I believe that the minimum thickness is 19mm. Is this crucial as mine have quite a lip so I need to measure the thickness ASAP. The pads are fine and the braking is good, will the sensors let me know if the discs are shot?
    Found some mintex discs and pads on fleabay total £60 which I thought was OK. Local garage man said approx £200 to supply and fit and another £45 to change brake fluid, so think I will do it myself. All help and advice is greatly appreciated.
    A, A
    Quote Originally Posted by alibla View Post
    What year is your car and ill check your minimum disc and pad thickness's.
    Mine were the mintex sets of ebay and they have been good to date.
    This is the ebay sellers shop: http://search.ebay.co.uk/_W0QQsassZq...r.partsQQhtZ-1
    A, A
    I had a guess:
    1.9 TDI PD Audi A3 (131 BHP) Engine Code: AZS, 2001-2003
    Minimums
    Front Discs: 23mm
    Rear Discs: 7mm
    Front Pads: 2mm (Excluding Backing plate & lining)
    Rear Pads: 7mm (Including Backing plate & lining)
    May 2007
    OLDHAM
    ATE braking system delphi part number pad LP1514 disc BG3036 vented
  8. Brakes
    May 2007
    Tamworth Staffs
    Cheers for the help and quick replies.
    Al
    West Yorkshire, UK
    Quote Originally Posted by mluton View Post
    Hi can you do it without the tool?
  10. front discs
    May 2007
    Tamworth Staffs
    Yep think so you only need the tool for the rear discs.
    Al
  1. Audi S4 front brakes! help
    By Lee_m in forum Audi A4 - Archive Topics
    Last Post: 21-12-2007, 01:33 PM
  2. W8 Front Discs and Pads
    By Dean 355 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-12-2007, 02:39 PM
  3. front brakes
    By frank99jc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-05-2007, 08:05 PM
  4. Stripping Front Brakes
    By stua4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-03-2007, 07:36 PM
  5. front discs
    By wilbur in forum 80 - 90
    Last Post: 10-01-2007, 10:39 PM
