Thread: Washer bottle won't fill above 1/4
  1. Washer bottle won't fill above 1/4
    Mar 2010
    I understand that the system is actually 2 bottles. I can't fill the top one above 1/4 full or it just pours out from the inside of the wing. I can't imagine that its a motor, since they are way below the level that it settles to. I thought that it was the joint between the bottles but that is also below.
    Has anyone got any experience of this? I'd like to get the parts before I pull it apart.
    P.S. Its the system without headlight washers.
    2002 A4 Avant 1.9 TDI 130
  2. Re: Washer bottle won't fill above 1/4
    chester
    17 Post(s)
    Mines the same,its got a nick in the side,its had a new front wing at some time before my ownership so I'm guessing it was done then,I just tolerate it.You may have frost damage from the hard winter,if you take it out you may be able to weld it.
  3. Re: Washer bottle won't fill above 1/4
    Southern County Softy
    20 Post(s)
    Take the wheelarch liner out and have a look where its leaking from.
    A4 2.5 tdi QS (mapped)
  4. Re: Washer bottle won't fill above 1/4
    Apr 2009
    Somewhere....Over The StrongBow
    These bottles can be mended with the resin (and hardener)
    from a fiberglass repair-kit.
    Regards
    Jim
  5. Re: Washer bottle won't fill above 1/4
    Mar 2010
    I don't think that polyester resin bonds well to polypropylene, and yes I can take the wheel arch cover off and look, but I was hoping for the voice of experience so I didn't need to do it twice.
    I'll report after the weekend.
  6. Re: Washer bottle won't fill above 1/4
    20 Post(s)
    take the liner out, see where the leak is, leave liner out until parts are sourced, replace damaged parts, refit liner, job done once.....
  7. Re: Washer bottle won't fill above 1/4
    Apr 2009
    Quote Originally Posted by pbassred View Post
    For more experience than these posters, you'll need to hear a
    voice from beyond the grave!
    Polyester resin will bond well with polypropylene, provided you don't exceed
    the recommended percentage of hardener, which can result in excess heat that
    in turn melts the polypropylene . I've successfully carried-out this exact repair many times, as it's a common result of front n/s prangs, (along with
    the inter-cooler getting twisted). Its cheap, easy, effective and sits on a
    shelf .
    Regards
    Jim
  8. Re: Washer bottle won't fill above 1/4
    Mar 2010
    Took the liner out, filled the bottle .... no leak. What might have been happening is the water was draining from the top tank in to the bottom one, which made it look like it disappeared.
    Put the liner back - job done.
    The strainer from the fill hole has gone missing now!
  1. Please Help Access to washer bottle pipes
    By jfannon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-12-2010, 06:33 PM
  2. Washer bottle empty warning when full
    By NickPicks in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-05-2010, 08:15 AM
  3. Please Help Audi A4 Washer Bottle Leak
    By Audichap in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2010, 05:04 PM
  4. Please Help '02 Polo washer bottle access
    By Snipey in forum Polo - Derby - Lupo - Fox
    Last Post: 31-01-2010, 10:45 PM
  5. Leaking Windscreen Washer Bottle
    By vwbolton in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-01-2010, 06:32 PM
