Thread: polo twist 2004 split bush
Results 1 to 8 of 8
  1. Unhappy polo twist 2004 split bush
    Sep 2007
    Front passenger side really creaky, apparently split bush. Anyone out there had the same problem. Apart from payingout £150 any suggestions. Want to sell the car now and the noise is same (tried wd40).
  2. Re: polo twist 2004 split bush
    Bristol
    You need to spend the £150. Mine went last year and the car failed it's MOT. They're consumables- no different to brake disks, you just have to replace them.
  3. Re: polo twist 2004 split bush
    Sep 2008
    Isleworth, West London
    bush is about a tenner from gsf, and changing them makes a whole world of difference to the car. I would change both (left and right). Its not that bad of a job, there are quite a few write ups.. google is your friend
    I did both of mine myself... all you need is a strong bench vice and something to press the old push out, I made a metal collar, did the job just fine.
  4. Re: polo twist 2004 split bush
    Feb 2011
    newcastle
    Really common fault. there is now a moddified bush. make sure the bush has 4 supports instead of 2. If they try to give you a bush with only 2 supports dont take it or you will be doing the same thing again next year.
    Not to bad to replace but you will need a tool to press the new bushes in. all you need is a threaded bar and 2 round plates just bigger then the bush.
  5. Re: polo twist 2004 split bush
    Jan 2009
    towcester northants
    if its the rear wishbone bush replace with the seat solid bush 6ll part no
    they make a big difference and dont go again
    as for £150 it not the easiest of jobs as you have to take off the alloy brackets to do the bush
    and front wheel alignment should be reset
  6. Re: polo twist 2004 split bush
    Nov 2008
    Just had this done - book time is 1.2 hours so ought to be about £100 all in - for both sides.
  7. Re: polo twist 2004 split bush
    Jan 2009
    towcester northants
    yes thats just for the bush to be replaced
    the front wheel alignment must be done as an extra part of the job
    thats camber and track if its done correctly
  8. Re: polo twist 2004 split bush
    Nov 2008
    thats very true - the tracking was an extra £40.
    Actually it was a tyre wearing on the outer edge that led me to find the worn bush.
  1. Car Of The Year - 2010 vs 2004
    By percymon in forum Polo - Derby - Lupo - Fox
    Last Post: 13-06-2011, 02:22 PM
  2. Volkswagen Polo Twist 2004 No audible warning sounds
    By fido18 in forum Polo - Derby - Lupo - Fox
    Last Post: 20-08-2009, 10:57 AM
  3. Replies: 0
    Last Post: 10-08-2009, 09:47 PM
  4. Volkswagen announces prices for new polo as car goes on sale
  5. Replies: 0
    Last Post: 06-10-2004, 09:22 PM
