Thread: None of the lights inside the car is working
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. Exclamation None of the lights inside the car is working
    Feb 2011
    Norway
    Hi!
    I've got this 97/98 Passat (1.9 Tdi) and i had ALOT of problems with it.
    The latest problem, that i can't seem to fix, is that ALL the lights inside the
    car (roof, over the doors etc) have stopped working. The dashboard lights work
    just fine (except the ones around the heat/strenght/type on the clima control)
    I've changed all the 5a fuses but nothing happend. I've checked the bulbs and they seem fine (the wire inside are intact)
    Is there anything i can do?
  2. Re: None of the lights inside the car is working
    Norfolk
    Interior lights are powered form the ccm under the passenger seat/carpet. Have a look at the wires and connector.
  3. Re: None of the lights inside the car is working
    Oct 2005
    sligo ireland
    have same prob no interior lights but workingat the heating what fuse controls them
    paul
  4. Re: None of the lights inside the car is working
    Feb 2011
    Norway
    Under the passenger seat? Is this all models or the UK model. I have a faulty CCM/CCU under my driverseat from a water leak. I've tried to get a replacement, but with no luck. I've have bought like 5 diffrent boxes, but all came with a diffrent serial number and opposit connectors.
  5. Re: None of the lights inside the car is working
    Norfolk
    Sorry. I should have said under the left seat. In the UK that is the passenger seat. The ccm changed connectors around 1999 so you probably have an early one. I would check the wires and connections. Often the ccm is still ok.
  6. Re: None of the lights inside the car is working
    133 Post(s)
    1985 Post(s)
    You will probably find all the wires in the harness in front of the convenience module box are corroded on the junctions, particularly the big group of red/black wires which provide all the courtesy light power. Get the carpet up and the harness/conv box pulled out and unwrap the tape. Check the grouped wiring by pulling on the wires and they will probably all fall to bits.
  7. Re: None of the lights inside the car is working
    Scottish Borders
    I have a 2002 TDI passat estate. I've got the same problem with no interior lights working. Last year the car alarm would go off without notice but that seemed to stop after a few weeks. I did as Crasher suggests and examined the ccm and wiring with it. Sure enough soaking wet under the carpets. Corroded contacts at the ccm were cleaned but still the same. Wiring loom connectors (esp red/black) tugged like mad but all ssems strong and clean looking inside the clear plastic tubing. Fuses all fine. I'm stumped. So if anybody can relight my interior I'll be most grateful.
  8. Re: None of the lights inside the car is working
    133 Post(s)
    1985 Post(s)
    Check for power to the red/black junction.
  9. Re: None of the lights inside the car is working
    Scottish Borders
    Hi. At long last I've got round to having another go at trying to get my interior lights to work. All of the connections in the undercarpet harness are sound and tested. There is power going through the red/black wires to the CCM. All fuses are good. Do I need to get a replacement CCM or is there anything else I can do? Would an auto-electrical specialist be able to help? I read somewhere that the master switch for the interior lights is in the drivers door lock - is that so and could that be the solution? Thanks again Crasher for your help to date.
  10. Re: None of the lights inside the car is working
    133 Post(s)
    1985 Post(s)
    The drivers door unit does command the interior lights but so do the others so I can't see it being the door lock. Without having VCDS available you are going to struggle to diagnose the problem without substituting anther convenience unit but I am experiencing more and more problems with them as they age. I had one faulty last week and the two used units I sourced were also faulty.
  1. 1.8T Common Troubleshooting Guide
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2010, 12:17 AM
  2. Integral Bluetooth radio for A4
    By Gary M in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-03-2010, 03:45 PM
  3. Wishbone Front / Rear Axle Bush which brand
    Last Post: 23-05-2009, 12:27 AM
  4. brakes stopped working coming upto the lights!
    By ritter1 in forum Golf MK3 - 1993 - 1999
    Last Post: 04-05-2009, 10:02 AM
  5. "How To" The FAQ & How To Thread
    By Ben in forum General
