Thread: Differences between the versions of VCDS??
Results 1 to 10 of 12
  1. Question Differences between the versions of VCDS??
    Jonny88 Guest
    Hi all,
    Was just wondering is someone would be able to clarify for me the exact differences between all the versions of VCDS??
    As far as I understand, there is VCDS Lite (the free version from Ross-Tech with limited capabilities), VCDS that costs $99 ish and the full version for $500 ish?
    Is that right? I understand that the full version is the all encompassing, does it all, flashing lights etc etc. But what are the differences between the free version and the $99 version?
    Any help much appreciated.
    Cheers.
    J.
  2. Re: Differences between the versions of VCDS??
  3. Re: Differences between the versions of VCDS??
    Jonny88 Guest
    Thanks for that.
    Where it mentions "Registered Version Only", is that referring to the version you have for paying $99 to register it i.e. shareware?
  4. Re: Differences between the versions of VCDS??
    Yep.
  5. Re: Differences between the versions of VCDS??
    Jonny88 Guest
    Thanks Esh.
    Quick question, what kind of lead do I need to run versions above 409.1???
    Thanks.
  6. Re: Differences between the versions of VCDS??
    Sep 2009
    Apollo
    409 is not supported anymore. VCDS-Lite has replaced it and the SW is available for DL here:
    http://www.ross-tech.com/vcds-lite/download/index.html
    Any version higher than the old 409 and VCDS-Lite requires a genuine intelligent interface. Users of our genuine intelligent interfaces can update using this page:
    http://www.ross-tech.com/vcds/download/current.html
    What cars do you plan on scanning so we can make the proper recommendation?
  7. Re: Differences between the versions of VCDS??
    Jonny88 Guest
    Quote Originally Posted by Dana@Ross-Tech View Post
    Thanks for explaining that Dana.
    I'm planning to scan a VW Mk4 ('02) Golf GT TDi (150BHP). So as I understand it, version 409.1 has been replaced by VCDS- Lite right?
    I may be being serisouly dim but from what I can see the cable itself costs $249???? That's a seriously expensive bit of wire! What are the software costs on top of that?
    Which cable would I need to scan my Golf???
    Thanks.
    J.
  8. Re: Differences between the versions of VCDS??
    Mar 2008
    High Wycombe
    The cable contains the hardware key (dongle) that lets the software run. The software is "free" although support is included in the cost of the cable for the original owner only, so if you buy a used dongle cable, you won't get support unless you pay $99 for it (so if you buy a used cable, make sure it's at least $99 less than a new one.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  9. Re: Differences between the versions of VCDS??
    Sep 2009
    Apollo
    Quote Originally Posted by Jonny88 View Post
    Thanks.
    J.
    For a MK4 your options would be:
    1) The third party cable and VCDS-Lite. You will need to see the vendor (of the 3rd party cable) for support if you have any connectivity issues. The SWL can be purchased from us if it works for you. The license is tied to one PC.
    2) The KII-USB. That isn't a "wire"... rather an intelligent interface with built in activation and dongle/software license as Nick mentioned. Once you own it, you can put VCDS on as many PCs as you like without any activation codes and so on.
    We can provide you with start-up support as well, providing you purchase new from us or any of our authorized distributors -or- pay to register for support if you purchase a system second hand.
    Drifty Guest
    Hi Dana, I'll be picking up my Passat CC 2011 spec (new build) early April. Could you let me know your recommendations/options please?
  1. A6 C6 VCDS Changes - Post & Pre Facelift
    By MFGF in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-11-2022, 09:33 PM
  2. Please Help Do You have VCDS
    By martin1810 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-01-2014, 11:17 AM
  3. VCDS OR VAG CAN Commander
    By Tariq Malik in forum VCDS - Help Requests
    Last Post: 12-03-2010, 03:02 PM
  4. Question Differences between the versions of Radio
    By nm2003 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-05-2009, 08:08 AM
  5. Replies: 0
    Last Post: 23-02-2006, 02:26 PM
