Thread: Emmision Control Light S4
Results 1 to 9 of 9
  1. Emmision Control Light S4
    Feb 2011
    London
    Was wondering if anyone can help.
    I have a 2006 Audi S4. The Emission Control light came on and the car is now slightly jumping/jerking, even when non idle.
    Any ideas what it could be and how it could be resolved?
    S
  2. Re: Emmision Control Light S4
    Emission control light is what used to be called the Check Engine Light or Malfunction Indicator Light.
    It means the ECU has detected something and logged a fault code. You need to get the car scanned for faults.
  3. Re: Emmision Control Light S4
    Southern County Softy
    20 Post(s)
    I would suspect a failed coil pack.
    Scan for faults first.
    A4 2.5 tdi QS (mapped)
  4. Re: Emmision Control Light S4
    Feb 2011
    London
    Quote Originally Posted by iwaters View Post
    Thanks.
    Worrying part is the car jumps and jerks slightly, but the engine runs fine. I just booked it into a local garage for a scan,lets see what comes up.
    Also, any chance you can enlighten as to what the potentail problem may be.
  5. Re: Emmision Control Light S4
    Feb 2011
    London
    Quote Originally Posted by kite View Post
    Thank you
  6. Re: Emmision Control Light S4
    As Kite says sounds likely to be a coil pack. The description you gave sounds like an enigne missfire. Could be other things though.
  7. Re: Emmision Control Light S4
    Feb 2011
    London
    Apologies to sound completely car ignorant. But is that a big issue or a lot of work required and expensive?
  8. Re: Emmision Control Light S4
    Assuming it is a coil pack, it is very little work involved in changing it. Not sure how much the part costs but wont be massive amounts of cash.
  9. Re: Emmision Control Light S4
    Feb 2011
    London
    The final Cost came to 250 pounds not sure how the priced that form an independent garage.
    Ask audi, their charge is £35 for the ignition coil, £140 labour and VAT. but they all so need to doa diagnostic to it will be a further £100 .
  1. Please Help Emission control sys light / Fuel temp sensor
    By StevenG191919 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-07-2015, 01:37 PM
  2. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  3. Bentley announces detailed specification of new mulsanne
  4. S4 Review...
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-05-2009, 09:24 PM
  5. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
