Thread: A4 B8 Westfalia Towbar and Dedicated Electrics
Results 1 to 10 of 15
  1. A4 B8 Westfalia Towbar and Dedicated Electrics
    Feb 2011
    I fitted the above yesterday having looked for hints and tips through the forum. Lots of stuff on older chassis, but not so much on the B8 so if anyone is considering doing it themselves and have any specific quetions, let me know.
  2. Re: A4 B8 Westfalia Towbar and Dedicated Electrics
    May 2007
    knee deep in clunge
    14 Post(s)
    straight forward pin swap and vcds coding but depending on build date you need to fit the uprated cooling fans because the engine overheats, I posted the info on this forum along time ago
    https://www.vwaudiforum.co.uk/forum/s...ight=b8+towbar
  3. Re: A4 B8 Westfalia Towbar and Dedicated Electrics
    Jan 2011
    Up North
    I've got a fairly recent A4 B8 (July 10) that doesn't need all the additional cooling updates that earlier versions did. I'm about to fit the Westfalia towbar and dedicated electrics and wondered if anyone has a list of exactly which VCDS updates are required as there seem to have been many modules mentioned.
    Is this an update that would, if made at a dealers, be uploaded to Audi's servers and therefore never be removed by future software updates? Do independent Audi specialists have that ability or would it only be official Audi dealers?
  4. Re: A4 B8 Westfalia Towbar and Dedicated Electrics
    May 2007
    knee deep in clunge
    14 Post(s)
    Ring your local dealer before fitting and ask will they run the svm update to add the towbar onto the vehicle specific build which makes the change permanent and then updates the data base for future updates etc
    If not then you can change the soft coding with vcds and at a later date if the dealer needs to run any updates then they will need to run the svm any way as the gateway installation change will prevent the vas from opening guided fault till correctly configured
    You may find they refuse as they then under take the liability for your work.
  5. Re: A4 B8 Westfalia Towbar and Dedicated Electrics
    Jan 2011
    Up North
    Do you happen to know just what it is that the dealer needs to do when I take it in? I've booked it in with them, and they were fine with that, but when I asked how long it would take they said a couple of hours as the coding itself takes very little time but it takes time to work out just what needs to be done!
    If anyone knows just what needs to be done I'd appreciate the info as I could pass that to the dealer and saved being charged extra labour time!
    Thanks!
  6. Re: A4 B8 Westfalia Towbar and Dedicated Electrics
    Feb 2011
    Rhino7, have you fitted the towbar and wiring now? If so what did you find, when you started the car for the first time in terms of errors. Also, I haven't got round to taking my car to the dealer yet so it would be great to hear how you got on once you've been.
  7. Re: A4 B8 Westfalia Towbar and Dedicated Electrics
    Jan 2011
    Up North
    Hi Madsplasher!
    I've not had it fitted yet, still a couple of weeks away. That was the earliest I could get it done (for several reasons) and I've booked it in to the dealers for a couple of days after that. I'll certainly let you know how things go if you haven't sorted yours by then.
    I'd still like to know details of what the dealer needs to do in order to avoid being ripped off!
  8. Re: A4 B8 Westfalia Towbar and Dedicated Electrics
    Feb 2011
    Hi Rhino7
    Sorry, can't help as I haven't had it re-coded yet and since the dealer is 35 miles away, it'll have to wait unitl I'm across there for something else.
    I don't work on cars very much - motorbikes are my thing - and since I don't have access to the service manual or the likes I was feeling my way a bit. You may know the car inside out, but if there's anything you want to know about actually fitting the kit, let me know.
    I asked the harness supplier what to expect in terms of errors after I fitted the kit and they told me the ESP light would be on until the car was recoded. And sure enough, that's exactly what I have. The towbar electrics all work fine though.
  9. Re: A4 B8 Westfalia Towbar and Dedicated Electrics
    Mar 2009
    Manchester, England
    When you take the vehicle in they will plug your car into the computer and load the trailer stability program (TSP) onto the vehicles ECU which will optimise the vehicle for towing and also remove the light from the dash, the dealer normally charge no more than an hours labour to do this but it has been known for different dealers to charge different prices so it might be worth having a phone around Thanks Dale
    PF Jones Towbars | National Mobile Towbar Fitting | Audi Towbars
    We will beat any like for like price on all Witter and Westfalia Towbars 0161 872 4755
  10. Re: A4 B8 Westfalia Towbar and Dedicated Electrics
    Feb 2011
    thanks for that information. Will the download also disable the reversing sensors when a trailer is fitted because I've noticed these still work which makes reversing noisy!
  1. Golf Mk 6 towbar and electrics - help!
    By mrmagoo2 in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 28-06-2022, 10:23 AM
  2. Towbar electrics help
    By patrickhorton in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-07-2011, 09:47 PM
  3. Replies: 0
    Last Post: 30-08-2010, 08:05 PM
  4. advice on tow bars and electrics
    By mya4audi in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 01-07-2010, 05:08 PM
  5. 2002 towbar electrics
    By faticus in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 23-03-2008, 10:30 PM
