Thread: Will this offset fit?
  1. Will this offset fit?
    Dec 2007
    Bedford
    I've seen a set of genuine 18" Audi A4 alloy wheels off a 2009 B8 and want to know if they will fit my B7?
    The PCD / Bolt Pattern is all the same.
    My offset is 45 but the B8 wheels have an offset of 47... Will that be a problem?
    2017 Audi A5 (B9) Coupe 2.0 TDI S-Line Quattro S Tronic
  2. Re: Will this offset fit?
    Mar 2010
    liverpool
    this aint really any help as not giving you a definite answer but, have a b6 and offset is 35 to 45 and i thought it was the same for the b7.
    1.8T, votex bodykit, 18" RS4's, tinted windows.
    scouser, but car was bought and paid for.
    Dec 2007
    Bedford
    Hiya,
    Yea your right the B6, B7 both have the same... I know mine are 45 just wondered if I can put 47 on them.
    I don't think it will be an issue.
    The tyre size is 245/40/18
  4. Re: Will this offset fit?
    Mar 2010
    liverpool
    sorry not sure. it will be tight and also your car has been lowered. from a personal point of view obviously et47 will sit back in your arch but if get wheels with et lower sit further out and i think give car a more aggresive look (but thats me)
  5. Re: Will this offset fit?
    Bratty Guest
    A 2mm difference in the offset would not cause any structural fouling (as long as the wheel widths are the same ie.8J), the manufacturers tolerances are pretty generous, the problems are normally caused by incorrect tyre choice.
    But you might need spigot rings as the centre hole on a B8 wheel is 66mm and I think that B7 is 57mm (not 100% sure on that point but worth checking out).
    Dunk
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. Kwik Fit Air Con Service
    By Pittsey in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-06-2009, 12:30 AM
  3. golf estate roof bars to fit rails
    By rotary in forum Golf MK4 - 1999 - 2004
    Last Post: 04-08-2008, 06:34 PM
  4. Tdi Sport 2006 Alloy Wheels Not Fit Mk4
    By drfe11a in forum Golf MK4 - 1999 - 2004
    Last Post: 30-04-2008, 09:13 AM
  5. Volkswagen Express Fit saves customers money
    Last Post: 03-07-2004, 08:18 PM
