Thread: EPB Tool
Results 1 to 10 of 19
  1. EPB Tool
    DSG4ME Guest
    Been reading up, and there seems to be one or two that work, one is a Laser one and the favorite is a Autel one.
    http://cgi.ebay.co.uk/Laser-Tools-EP...14148632016550
    http://cgi.ebay.co.uk/058-UK-EPB-Res...65373104354954
    http://cgi.ebay.co.uk/Brake-Pads-Res...73416504178222
    http://www.auteltech.com/pdf/EST201_...0_20090319.pdf
    Anyone got or used one of these yet?
    Oct 2010
    Here And There
    Can you not just use vagcom ?
    Sent from my iPhone using Tapatalk as I cant be ***** turning on my laptop !
  3. Re: EPB Tool
    Mar 2010
    london uk
    i have an autel 4805 something like that,i had bought it to switch off the airbag light on my 55 passat.done it in the first place then the light came back again and wont go now
  4. Re: EPB Tool
    Norfolk
    You can't just switch off a fault light. You have to fix the fault. You obviously still have a fault.
  5. Re: EPB Tool
    DSG4ME Guest
    Quote Originally Posted by gireada2005 View Post
    Get under the front seats and check the plugs, iirc hoovering can displace them, as you have the tool it shouldn't hurt disconnecting them and then reconnecting them to make a full contact, then put the lights out with the tool, wait until Martin replies again before you do though just incase it can cause issues.
  6. Re: EPB Tool
    DSG4ME Guest
    Quote Originally Posted by Bangor Lad View Post
    Not at £250 for a lead and a cd, that one is only any good if it's going to get used, too much for simple opps on the car once in a while.
  7. Re: EPB Tool
    May 2010
    Devon England
    We can do this at work with Texa but having seen the units on the links its the sort of thing that looks easy to use, sort of thing that would be ideal in my tool box may have to look in to them a bit more, save getting the lap top fired up
  8. Re: EPB Tool
    DSG4ME Guest
    The thing I'm not sure on is the Adaptation at the end of replacement, this seems to be a calibration thing to set the caliper up, but there's not much info regarding the width you should set it to, it's on page 13-14 in the pdf for the Aut tool.
  9. Re: EPB Tool
    Norfolk
    This is where VCDS is much better than a hand held tool. With VCDS you can see the motor current peak as the motor winds the new pads into place. It is the current peak that tells the epb controller that the brake is full on. Now the controller can calculate how much to unwind to release the epb. As long as a hand held tool measures the current peak correctly. It can reset the epb. Winding the motor back can be done with anything. Getting the motor back to the "set" position is the hard bit.
  10. Re: EPB Tool
    DSG4ME Guest
    I'm tossing up either the Autel 201, or the Vscanner Pro, I think Esh has had the pro before, so i'll ask him what it performed like later.
  1. How do you reset automatic roof?
    By katecar in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2017, 12:41 PM
  2. Please Help Audi A4 Cabrio Hood Problem
    By vaslam1986 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-10-2010, 12:08 AM
  3. Please Help EPB Did garage burst it?
    By dug8018 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-04-2010, 09:16 PM
  4. Sealey Brake Caliper Wind Back Tool
    By Zedrider in forum Chat - Completely Off Topic
    Last Post: 03-12-2009, 11:57 PM
  5. VAG-COM : Exhaust Gas Warning Lamp
    By mlakhi in forum VCDS - General Questions
    Last Post: 03-06-2009, 08:56 PM
