Thread: engine management light! help!!
Results 1 to 10 of 15
  1. engine management light! help!!
    Feb 2011
    Walsall, UK
    hello, just recently bought a remapped vw golf mk5 1.9 tdi 54 plate. remapped from 105 bhp to 150bhp. after a couple months of driving, one day i gave the car alot of throttle and the engine management light appeared (whoops).
    i had a diagnostic done and the code was for the motor for the intake manifold flap, which i then replaced. and my mechanic cleared the codes, however 5 mins later the light came back on came back on and this time the diagnostic read fault codes:
    p3101 - motor for intake manifold flap open or short to ground
    p0691 - fan 1 control circuit short to GND
    any ideas as to how i can resolve this problem and could it be because of the remap as i was told 150bhp is too much power taken out of the car?
    sorry to make this an essay but any sort of help would be appreiciated.
    thanks
  2. Re: engine management light! help!!
    May 2010
    Devon England
    hi mate my 105 has been mapped to 140 and had no problems, now you have blown a fuse in the fuse box under the bonnet, the 140 2 lts have the same throttle flap issue and blow the fuse, if you chech all the fuse's in the box near the battery and replace the blown fuse, then have the codes deleted that should cure your fault, hope this helps mate
  3. Re: engine management light! help!!
    Feb 2011
    Walsall, UK
    thanks for the reply mate. do you have any idea as to which fuse it could be?
  4. Re: engine management light! help!!
    May 2010
    Devon England
    its fuse F8 mate, not sure of its location in the under bonnet fuse box but iirc there is only 9/10 and they are easy to get at
  5. Re: engine management light! help!!
    Feb 2011
    Walsall, UK
    mate your a life saver you've just save me £35 an hour of an auto electrician lookin over my car. thannks really appreciated
  6. Re: engine management light! help!!
    May 2010
    Devon England
    Quote Originally Posted by kuz27 View Post
    thats ok mate anytime hope its all sorted bud
  7. Re: engine management light! help!!
    Feb 2011
    Walsall, UK
    Cheers mate.. But the fuse blew and the light came on again and it read the manifold flap intake- no signal, which is the actual flap itself again which i had changed. So could I have bought a faulty part? As I purchased it from eBay.
  8. Re: engine management light! help!!
    Manchester
    Possibly bud.. I bought mine from TPS £250 ish if i remember.. easy to fit just need VAGCOM to reset.
    Mk6 Golf 2009 Deep Black Pearl 2.0 GTTDI 140, Vancouvers
  9. Re: engine management light! help!!
    May 2010
    Devon England
    if it was a S/H one then there is a strong chance its knackered, GSF do them for £170 + vat, also just make sure both rad fans turn freely, it could be one of them is siezed and its blowing the fuse
  10. Re: engine management light! help!!
    Feb 2011
    Walsall, UK
    sorry to long this out but i got a different guy to do a VAGCOM diagnosis and the part number came up as 03g906016cb rather than 038128063g (which is the part i matched up with the original manifold flap that stopped working). i am totally confused as to which part i require??
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. Question Engine Management Light
    By bigmikeyoyo in forum Golf MK4 - 1999 - 2004
    Last Post: 04-11-2010, 10:47 PM
  3. Engine Management Light A4 TDi 130
    By MikeRyan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-06-2009, 09:37 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. A4 engine management light .help
    By piggyA4 in forum Audi A4 - Archive Topics
    Last Post: 28-11-2007, 12:25 AM
