Thread: Battery / Charging system diagnosis?
  1. Battery / Charging system diagnosis?
    GAZ_XB9R Guest
    As per previous post, I have run a scan and found most controllers exibitted faults for Supply Voltage B+ Lower Limit Exeeded and Function Limitation Due To Under Voltage.
    The car on a few occasions has not started and has been charged for in excess of 5hrs with an 11mA charger.
    After a run of approx' 7miles each way to the supermarket where the car was left running two days ago, I today hooked up VCDS again to interrogate the Battery Regulator Module. After this the car tried to start but was unable and the battery was again dead.
    I'm charging again and will hopefully get some info when running to gauge if the charging system is operational and get some more VCDS screen dumps.
    I am unsure if the battery is knackered or the charging system is not functioning or even if there is an abnormal drain on the battery.
    Can anyone help demystify the info' I have managed to get from the Battery Regulator.
    [IMG]file:///C:/Users/Home/AppData/Local/Temp/moz-screenshot.png[/IMG]
    2007 Q7 3.0 TDI S-Line
  2. Re: Battery / Charging system diagnosis?
    Southern County Softy
    20 Post(s)
    I would get the battery checked
    A4 2.5 tdi QS (mapped)
    Oct 2010
    Here And There
    Obviously charging her alone is doing no help matey. Its sounds like your battery is scrap but to make sure that she is charging, you will need to check your battery voltage with vcds or mulitimeter while the engine is running with all your consumers on at the same time ( main beam, full heater fan speed, heated windows and radio ) and the repost your results.
    Sent from my iPhone using Tapatalk as I cant be ***** turning on my laptop !
  4. Re: Battery / Charging system diagnosis?
    GAZ_XB9R Guest
    Got her running again after a 2.5hrs charge.
    Took a few more screen shots. Charging system looks like it's working but I'm no expert. I'll try starting her again later this morning and checking the voltage with full load.
  5. Re: Battery / Charging system diagnosis?
    GAZ_XB9R Guest
    This morning 12.1V using a multimeter.
    Back on charge for a couple hours then down the shops and back.
    I'll get another set of VCDS screenshots on full load.
    Anyone any ideas as to the "Qv (Battery Aging) 0Ah & 54Ah" are?
    Also any ideas on the following DTC?
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4L0 910 181 HW: 4L0 915 181
    Component: J0644 BEM H12 0530
    Revision: -------- Serial number: 00000000018869
    Shop #: WSC 00861 210 91451
    VCID: E4C353F85EDD
    Part No: 4F0 915 105 D
    Component: von VA0 390219J22S
    Coding: 34463039313531303544205641303339303231394A323253
    Shop #: WSC 00861 210 95080
    3 Faults Found:
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 7
    Reset counter: 194
    Mileage: 53889 km
    Time Indication: 0
    Date: 2009.11.26
    Time: 21:52:00
    Cheers Gaz
  1. Replies: 7
    Last Post: 02-09-2012, 04:40 PM
  2. Audi a1 e-tron – zero-emissions in the city
    Last Post: 02-03-2010, 07:54 PM
  3. Audi a1 e-tron – zero-emissions in the city
  4. Please Help Battery + Climate Control Unit + Engine + What's next?
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2009, 07:39 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
