View Poll Results: At 233,000 Miles (51 plate), should I replace my 1.9TDI A4?
Voters
5. You may not vote on this poll
  • Yes
    0 0%
  • Just run it till it dies
    2 40.00%
  • No
    3 60.00%
Thread: Water Pump Failure
  1. Water Pump Failure
    Sep 2009
    Chester-le-Street, UK
    I am driving a 51 plate 1.9 TDI. Was driving home from work when the water pump went. The low coolant message came on and could hear that a bearing had gone.
    when I got home, filled the coolant to the brim and then tried to drive it to the garage who were going to replace the pump (bout 7/8 miles away) got onto the motorway when the car when into uber limp mode, (wouldn't let me go above 2000RPM) and the coolant Message came back. Knowing this wasn't good, I pulled over but as I came to a stop, the engine cut out. The water pump has now completely gone (pour water into reservoir, it comes straight out the pump) and I have had it towed to the garage.
    My concern is the car won't start.... I don't want to spend the money repairing the water pump to find that there is something much worse wrong! It turns over fine but just won't start. Is this the ECU refusing to let the car start until I have fixed the water pump (not sure how it knows) or is this the sign of a worse problem???
  2. Re: Water Pump Failure
    Sep 2008
    chester
    17 Post(s)
    Take the cambelt top cover off and check the cambelt I think you've most likely thrown the belt off the sprockets, big big problem.
  3. Re: Water Pump Failure
    Dec 2006
    Sorry to say..
    Could be a big problem.... the water pump is on the same belt as the cam belt...
    If the pump has locked out or collapsed it may of taken the cambelt with it and more than likely caused some damaged to the engine...
    If the water pump fails and its a impeller issues.. you "can" be ok to drive a mile or 2..
    Once that cam cover is off you will be able to see in more detail....
    Only option is to start the job and take it from there.
    Good Luck.
    Rick
  4. Re: Water Pump Failure
    Jun 2008
    Beverley, east Yorkshire
    sounds bad, you have probably cooked the head, maybe cylinder head gasket is dead. It maybe simple, i hope so
    A4 AVANT 2.5TDI SPORT QUATTRO
  5. Re: Water Pump Failure
    He states the engine turns over okay but will not start,if the belt had failed i don't think the engine would turn over,one tooth out and thats it.wodering if the engine can have overheated causing some other issue
  6. Re: Water Pump Failure
    Sep 2008
    chester
    17 Post(s)
    Once the pistons have clouted the valves the damage has been done and it will crank over,you can tell by the ease of cranking it over(no compression)hope not for your sake pal.
  1. Please Help coolant system circulation
    By FLENG2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 25-02-2010, 08:13 PM
  2. Water pump replacement
    By Norman vwp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2009, 06:58 PM
  3. 1.9 Diesel water pump change
    By Pickard1 in forum Golf MK3 - 1993 - 1999
    Last Post: 24-05-2009, 10:10 PM
  4. Question Water pump raplacement
    By adamflint23 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-05-2009, 05:01 PM
  5. WATER PUMP faulty - overheating 1.9tdi PD
    By mystic.bertie in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-05-2009, 03:39 PM
