Thread: Audi A6 2.5TDI 1999 Quattro starting problems
Results 1 to 10 of 12
  1. Audi A6 2.5TDI 1999 Quattro starting problems
    bristol
    Hi all.
    Good evening everybody. First post so go easy please...
    I have an Audi quattro 2.5tdi 1999 and the last three mornings the car has been very slow starting.
    After the heater plugs light goes out the car takes a good 10 seconds of cranking in order for the engine to fire. Once that happens a big cloud of white/ grey smoke leaves the exhaust. ( unused diesel?)
    After looking at the oil on the dipstick looks all black.
    And the water in the tank looks dark but not shinny or anything. or is this just the start and have stumbled onto a head gasket problem
    Can anyone help with diagnosing head gasket symptons, or other possible problems.
    The problem doesn't reappear for the rest of the day only again in the morning.
    Hope somesome out there may be able to offer some advice ( would be greatly appreciated).
    Thanks.
  2. Re: Audi A6 2.5TDI 1999 Quattro starting problems
    Mar 2008
    High Wycombe
    I'd be suspicious that some of the glow plugs are not working properly.
    Be warned though - I've heard that glow plugs are easy to snap off when removing and a nightmare to get out if they do.
    If you post your engine code (3 letters on the sticker in the service book or spare wheel well), then I'm sure that some of the very knowledgeable people here will advise on the specifics of your engine.
    The coolant should be pink. If it's brown, it probably needs changing.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Audi A6 2.5TDI 1999 Quattro starting problems
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    sounds more like fuel pump EDC to me, friend of mine just had same problem on his Allroad!
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  4. Re: Audi A6 2.5TDI 1999 Quattro starting problems
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I would put my money on glow plugs. Remove one of them and test the resistance. If I can recall correctly, a 1/4 in drive deep 10mm socket with extension bar should do, it should be only a few ohms. If greater than 200, then replace. The 2.5 needs glow plugs in sub 10C temps.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  5. Re: Audi A6 2.5TDI 1999 Quattro starting problems
    134 Post(s)
    2012 Post(s)
    Removing those glow plugs makes me feel queasy every time. I did a set a few weeks back and every one creaked and juddered coming out, not a pleasant experience. Whatever you do, once removed DO NOT refit a glow plug even if it works, a snapped one will ruin your day.
  6. Re: Audi A6 2.5TDI 1999 Quattro starting problems
    bristol
    Quote Originally Posted by NickPicks View Post
    Thanks very much for the advice, i'll be on that first thing in the morning.
  7. Re: Audi A6 2.5TDI 1999 Quattro starting problems
    bristol
    Quote Originally Posted by dean warren View Post
    Really worried at the cost of the fuel pump problem how would I go about checking for this?
    Many thanks
  8. Re: Audi A6 2.5TDI 1999 Quattro starting problems
    bristol
    Quote Originally Posted by shabazmo View Post
    Really, well its been 6C- 8C this week in bristol so that could work. thankyou for the advice. Any ideas on a haynes like manual for the car as haynes dont do 1999 2.5tdi or am I misaken.
    Regards
  9. Re: Audi A6 2.5TDI 1999 Quattro starting problems
    bristol
    So are you saying remove a glow plug test if it was ok and fit a new one. If it turns out to be bad then i'll know the culprit? Or replace all in one morning?
    Many thanks
  10. Re: Audi A6 2.5TDI 1999 Quattro starting problems
    Aug 2007
    Midlands, Uk.
    You don't need to remove the glow plugs to test. Take off the connector and just measure resistance from the tip to a good earth on the engine. Should be no more than a couple of ohms.
    When I checked mine they were all open circuit. But they're scary to change, lots of penetrating fluid and engine warm but managed it, they creak and groan on the way out. Don't re-use old ones, not worth it. Put a bit olf copper ease on the threads before you refit them.
  1. Advanced new audi a6 travels light to tackle emissions
    Last Post: 11-12-2010, 07:22 PM
  2. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  3. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  4. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  5. Audi launches a major broadcasting revolution
    Last Post: 31-10-2005, 09:01 PM
