Thread: 1.8T Low Boost
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. 1.8T Low Boost
    Aug 2007
    Cork, Ireland
    I hooked up my VAGCOM to the car and it showing a range of 90-150mBar boost while driving. (1-2psi)
    I'm getting no faults.
    I can hear the turbo whirring on start-up.
    - I checked the wastegate actuator, it's moving as the car is revved.
    - I checked the Ohms on the N75 valve, within range.
    - I'm pretty sure I've no leaks in the system
    - Replaced the DV last year and vacuum lines.
    Can any one please advise on what I should check next???
    Should I try unplugging the N75 and N249 valves and taking it for a spin?
    Thanks in advance,
    Skip
    4 Audi's or is it 4 Audi?
    02 - A6 Avant 1.9 TDi 130 Sport
    01 - A4 Avant 1.8T Sport
    98 - A4 Avant 1.8 SE - Bye bye Bluey
    92 - 80 Saloon 2.0 - My first love (for 10 years)
  2. Re: 1.8T Low Boost
    try unplugging N75
  3. Re: 1.8T Low Boost
    Aug 2007
    Cork, Ireland
    I tried that and it appeared to make no difference
  4. Re: 1.8T Low Boost
    Run the vehicle in 3rd gear give full throttle and take a reading of the AMM value
  5. Re: 1.8T Low Boost
    Aug 2007
    Cork, Ireland
    Tried that, unsuccessfully!
    It looks like I'll have to invest in the registered version of VCDS-Lite or find someone to read it for me while I drive.
    I'm going to test the system again for any leaks later today and maybe see if there is any play in the wastegate rod. Following that it might be take the CAT off and look at the wastegate flap...
    just as well i'd nothing planned for the weekend!
  6. Re: 1.8T Low Boost
    Aug 2007
    Cork, Ireland
    After doing some more research last night, I'm guessing that since unplugging the N75 didn't make any difference, then that is most likely the problem.
    I took the chance to retest for leaks in the system. None found
    I also took off the CAT to check the condition of the wastegate flap and actuator arm. Excellent condition
    There is a bit of play in the shaft, but nothing major (120,000 miles)
    I tested the wastegate actuator. perfect
    I got my code for VCDS-Lite late last night, so I'll try get the readings later and prehaps test the N75.
  7. Re: 1.8T Low Boost
    131 Post(s)
    1976 Post(s)
    How are you checking the charge air system for leaks?
  8. Re: 1.8T Low Boost
    Aug 2007
    Cork, Ireland
    I fitted a air connection to the hose when it attaches to the air filter box and slowly increased the pressure. Then to be sure, I blanked the hose at other end at the inlet manifold.
    Blanked the PCV and opened oil filler cap.
    The only noise was the bubbling oil in the sump, which I believe is air getting past the oil seal in the turbo.
  9. Re: 1.8T Low Boost
    131 Post(s)
    1976 Post(s)
    Well that’s the right way to do it, as long as you do not exceed a total pressure of 0.5 bar or you can blow seals. In your position, I would fit a separate pressure gauge now and make sure the signal from the map sensor was correct.
  10. Re: 1.8T Low Boost
    Aug 2007
    Cork, Ireland
  1. Question A3 1.8T Quattro Turbo Boost adjustment
    By Jungle in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 12-07-2010, 06:50 PM
  2. boost.... what boost???
    By mat_wye in forum VCDS - Help Requests
    Last Post: 06-06-2009, 08:32 AM
  3. (mbc) manual boost controller on 1.8t
    By sharpy1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-06-2008, 11:01 PM
  4. what boost on a3 1.8t ko3 turbo
    By webbyturbo in forum Audi A3 - Archive Topics
    Last Post: 12-03-2008, 11:01 PM
  5. A3 1.8T Turbo Boost
    By Peeps in forum Audi A3 - Archive Topics
    Last Post: 21-09-2007, 03:31 PM
