Thread: Engine management light doesn't work
  1. Engine management light doesn't work
    Dec 2009
    Dublin
    Hi all, I'm due to have my car test in the next month in Ireland and recently they introduced a new test on the engine management light. On turning the ignition it must light and extinguish to pass the test. Mine doesn't work at all. It hasn't worked in quite some time. Recently I've had work done by vw and since then my vagcom doesn't work, that's another issue as the light didn't work before the vagcom didn't and there was no fault code for it.
    Anyway my question is can a bulb be replaced? Is so how? If not what can I do.
  2. Re: Engine management light doesn't work
    The engine control light is not a bulb.it is a led and part of the dash circuit- board, it can be replaced,but it involves,removing the dash,and removing the circuit-board from the dash.Question is,is it the led or is something wrong with the circuit -board?
  1. Please Help Do You have VCDS
    By martin1810 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-01-2014, 11:17 AM
  2. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  3. The engine management light keeps coming on in my 2001 A4 2.0 petrol
    By ianglasgow in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-11-2009, 10:15 AM
  4. Please Help Engine Management Light on
    By babyjesus1985 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-11-2009, 12:14 AM
  5. A4 engine management light .help
    By piggyA4 in forum Audi A4 - Archive Topics
    Last Post: 28-11-2007, 12:25 AM
