Thread: Sinking break pedal after disc change
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. Sinking break pedal after disc change
    Mar 2008
    Warminster
    I put new front discs and pads on and eveything was fine. A few days later i changed the rears and now the pedal is sinking but gets hard when you pump. No loss of fluid, i didnt undo any pipes, just unscrewed the resovoir cap and wound the pistons in to fit new pads, any ideas
    many thanks, Chappers
  2. Re: Sinking break pedal after disc change
    Bad move in my book. When pressing/winding pistons back, you should fit a bleed pipe and crack the bleed nipple open, press the piston back slowly, close the nipple, fit the new pads and rebuild then bleed that calliper in the normal way and finally lock the bleed nipple off. You have forced old contaminated fluid back up the system.
    Make abolutely sure you are not leaking fluid at the rear banjo union. Common problem..
    To recover this suck out all the fluid from the brake resorvior and fill with fresh fluid then bleed all four callipers. Use an assistant and do not use the brake travel past 2/3rd travel. I assume, as a side issue, that you did put the front inner pads in on the correct side. They are sided and marked with an arrow of direction of rotation of that wheel. Get it wrong and the pads can knock every time you apply the brakes. Regards Peter
  3. Re: Sinking break pedal after disc change
    Mar 2008
    Warminster
    Pete,
    thanks for the reply, i will try that, the fronts seem ok and i dont recall any directional arrows on the pads but i will check. I thought it might have been the master cylinder but hope its as you suggest
    cheers Paul
  4. Re: Sinking break pedal after disc change
    What make where the pads, I have seen after market pads with no marking but many with as are the OEM ATE pads. Some pad sets come with instructions that detail the direction arrow and it's location.
    As you did not open the bleed nipples or pump the peddle why would the MC fail. I would be more concerned they you may have forced debris backwards through the ABS and if you knew what that cost you would open the bleed nipples. Regards Peter
  5. Re: Sinking break pedal after disc change
    Aug 2010
    Southampton
    This sounds the same as i recently had on my old M Benz 190.
    The brake master cylinder was the cause.
  6. Re: Sinking break pedal after disc change
    Quote Originally Posted by Peter D View Post
    Thanks for this Peter. Elsawin doesn't mention to open the bleed nipples but at least I know now for future.
  7. Re: Sinking break pedal after disc change
    Elsawin does not tell you to tighten a nut clockwise either, but there are some things you just have to know. Not only does undoing the nipple allow you to expell the contaminated fluid but it breaks the corrosion that can cause a nipple to sieze and then when you need to bleed the system you snap one off. Undo, clean, a little copper ease and do up when bled. Regards Peter
    2 0 0
  8. Re: Sinking break pedal after disc change
    Pembrokeshire
    22 Post(s)
    very worthwhile advice there.
  9. Re: Sinking break pedal after disc change
    True. But there are pages on how to remove a wheel though which you'd think even the thickest fitter at the main dealer could manage.
  10. Re: Sinking break pedal after disc change
    Yes and it also provides the fitting sequence of the bolts and the torque figure and tighening sequence. Regards Peter
  1. pads + disc change, 1997 cordoba, easy?
    By Team Davie in forum Ibiza - Cordoba
    Last Post: 24-01-2010, 10:48 PM
  2. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
  3. Clutch pedal over centre spring?
    By Bikerman in forum Golf MK3 - 1993 - 1999
    Last Post: 18-10-2007, 09:43 AM
  4. Kwikfit... huge problem !
    By thewiderview in forum The Commercial Range
    Last Post: 06-02-2007, 02:43 PM
  5. What Brakes
    By Tonka73 in forum Passat - Archive Topics
    Last Post: 08-01-2007, 01:11 PM
