Thread: Audi A4 Diesel Fuel Pump leak - AFN engine
  1. Audi A4 Diesel Fuel Pump leak - AFN engine
    Feb 2011
    hamilton
    I have a TDI 1.9SE 110bhp 1997 201K mileage.
    There is a small leak of diesel coming from the fuel pump.
    Someone has told me that it is the seal that is leaking and that you can purchase these from Audi.
    But the same person has also told me that this is a difficult process if you do not know what you are doing.
    Has anyone had this problem before and could anybody advise ?
    Cheers,
    Chris.
  2. Re: Audi A4 Diesel Fuel Pump leak - AFN engine
    london/ UK
    Which seal is leaking ? I hope is not the case seal on top of the pump-most common. If thats the problem then you need to get the pump set-up by a diesel specialist as most likely the new seals needs stretching over the case and will leak again. Taking it off will result in engine runaway ! People result in using biodiesel- this swells the seals and the leak stops for a while !
  3. Re: Audi A4 Diesel Fuel Pump leak - AFN engine
    Feb 2011
    hamilton
    I will double check which seal it is and get back to you if that is okay ?
  4. Re: Audi A4 Diesel Fuel Pump leak - AFN engine
    london/ UK
    Do a search on tdi forum as they have a how to with pictures on changing the seals for the pump top case... Just be carefull. As i said, i would try some biodiesel first as this might sweel the seals...
  5. Re: Audi A4 Diesel Fuel Pump leak - AFN engine
    Dec 2008
    Just thought I would post this....
    Any one got a leak from the Diesel Injector Pump... Look and learn!!
    This one of the cooling hoses which runs directly under the Fuel Injector Pump... Looks in a fair to good condition...
    My fuel pump started leaking in the beginning of December... ONE MONTH LATER the hose looked like this!!
    Luckily, I noticed this before the car lost too much water and before it got any hotter than normal...
    If you decide to leave the fuel pump leaking onto the hose, don't be surprised if this happens to your motor or worse!!
  6. Re: Audi A4 Diesel Fuel Pump leak - AFN engine
    Jan 2009
    Nuneaton England
    6 Post(s)
    Form personal experience I would recommend you contact http://www.dieselbob.co.uk/
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Binding brakes ??
    By mini mik in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-07-2010, 09:54 PM
  3. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  4. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
  5. Replies: 0
    Last Post: 23-02-2006, 02:26 PM
