Thread: A3 1.9 TDI (130) unknown werring noise
  1. A3 1.9 TDI (130) unknown werring noise
    Jan 2011
    Bath, UK
    Dear all audi boffins,
    I have an Audi A3 1.9 TDI (130) 2001 and I am getting a very distinct werring noise from the engine, it is very frustrating as I cannot seem to pinpoint where it is coming from. To describe my meaning of 'werring noise' it is definitely a spinning part like a bearing on it's way out.
    The noise seems as though it is coming from the left side of the engine, where the cam and timing belt are, I know it is not the cam belt tensioner as I have replaced that for a new one recently.
    The noise has been on and off for for some time, but has become more frequent. If I turn the wheels, left or right, it seems to exsentuate the noise, but the noise does occasionally persist without turning wheels at all. The noise does not get louder when I accelerate.
    That's all I can really say about it. I hope someone out there can help me with this as I do not want to take it into a garage, I look forward to your responses
    Kind regards
  2. Re: A3 1.9 TDI (130) unknown werring noise
    Jan 2011
    Bath, UK
    After some thought, it only seems logical that the part making the werring noise, considering the effects of turning the wheel left to right, is the power steering pump, which has spinning parts.
    It is most likely that one of the bearings is on it's way out, does anyone know if you can recondition these parts as they are fairly expensive, well I know you can recondition them as people are selling refurbished ones but the question is where can I get hold of the new components for the refurbishment ?
  3. Re: A3 1.9 TDI (130) unknown werring noise
    Southern County Softy
    20 Post(s)
    have you checked the PS fluid level, low fluid can make the pump noisy.
    A4 2.5 tdi QS (mapped)
  4. Re: A3 1.9 TDI (130) unknown werring noise
    check the alternator freewheel
  5. Re: A3 1.9 TDI (130) unknown werring noise
    Jan 2011
    Bath, UK
    Thanks for your replies, I checked the level of the ps fluid and as you suspected it is low, so I will top that up and see if it solves my issue.
  6. Re: A3 1.9 TDI (130) unknown werring noise
    rinupanu Guest
    I'm no expert, my friend had exact same problem, turned out to be wheel bearing and sensor, just a thought.
  7. Re: A3 1.9 TDI (130) unknown werring noise
    Aug 2010
    Bristol
    As mentioned, it'll be the power steering fluid being low.
  1. Question Gt tdi wheel noise HELP (long story)
    By Buzzoff in forum Golf MK5 - 2004 - 2009
    Last Post: 06-10-2013, 06:14 AM
  2. noise from engine 1.9 tdi pd 130 passat
    By dexsan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-11-2008, 10:25 PM
  3. Change from 5sp to 6sp
    By lowndsy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-11-2007, 08:14 PM
  4. Engine Noise passat tdi 130 auto
    By vw-passat-man in forum Archive posts
    Last Post: 16-09-2007, 05:16 PM
  5. New Audi A3 Will Be Free To Charge Into London
    Last Post: 20-08-2007, 08:55 PM
