Thread: Wing Sponges!
Results 1 to 10 of 20
  1. Wing Sponges!
    Oct 2006
    Just been reading about the corrosion issues because of the sponge behind the front arch liner.
    I haven't noticed any corrosion (yet) but wonder if the advice is to get these sponges out?
  2. Re: Wing Sponges!
    Apr 2009
    Quote Originally Posted by dickturpin View Post
    As the real **** Turpin would have said "Stand and De-liner"
    Regards
    Jim
  3. Re: Wing Sponges!
    Jul 2008
    Get rid pal, it rusts from the inside out.
  4. Re: Wing Sponges!
    Jun 2006
    UK, Mids
    Maybe you could soak them in waxoyl and put them back?
    They must be there for a reason.
    Audi A8 - 2015 - 3.0TDI
  5. Re: Wing Sponges!
    Oct 2006
    Interesting question......What are they there for????
  6. Re: Wing Sponges!
    Jul 2008
    I took mine out a few months ago. From what I read, they are there for sound insulation.
    I've had no noticeable increase in noise since getting rid.
  7. Re: Wing Sponges!
    Chipped2 Guest
    Yes you are better without them. But... the rust is caused when the lower edge of the foam rubs the inner lip of the wheel arch at its highest point. As this is an area that suffers from dust, dirt, grit, salt and vibration is rubs away the inner wheelarch paint/galvanizing to create the corrosion from the inside out which is exactly why your car is covered by a 12 year corrosion warranty.
    Remove this foam and you will negate your warranty. Try to repair yourself and again you will not be covered. VW are aware of the problem and will replace /repair your wing. If you present a vehicle that is scratched dented or has had the wing damaged/repaired previously don't expect much sympathy or help. Both Golfs and Passats are affected. Only VW approved paint and bodyshops can undertake any work.
    Polite persistence is required. There is a link in the Golf section to a vag confidential worldwide bulletin that you will find very helpful to download.
    If you consider a claim to be not worth your while then remove the foam and de-rust the wing but be prepared to find that the inner wheelarch lip simply crumbles even though it appears to be sound. New VW wings in primer were about £140 in 2010. Painting is the expensive part.
  8. Re: Wing Sponges!
    Apr 2009
    aproached main dealer about this,didnt want to know.Said it was acaused by plastic liner rubbing inside of arch,said no chance of claim,will not honor garantee?
  9. Re: Wing Sponges!
    Jul 2010
    Brighton
    Quote Originally Posted by swannswanny View Post
    What reason did they give ?? the cause is because of faulty materials which under the terms of the warrenty should be covered i would go back and kick up
  10. Re: Wing Sponges!
    Oct 2006
    Two questions arise....is it not appropriate to just trim off the lower part that rubs and collects grit? Also, isn't the people we need to 'kick of ' with VW rather than the dealer?
  1. Replies: 35
    Last Post: 22-01-2015, 11:12 PM
  2. Question Golf MK3 1.9D - wing issue inherited from previous owner
    By TheIconHBK in forum Golf MK3 - 1993 - 1999
    Last Post: 26-12-2009, 03:53 PM
  3. Heated Wing Mirrors
    By deviseruk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-04-2008, 09:46 PM
  4. Vw golf Mk4 .. Modified Wing Mirrors
    By Chris-B in forum Golf MK4 - 1999 - 2004
    Last Post: 22-03-2008, 09:44 PM
  5. How easy is it to change a wing?
    By Androo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-01-2008, 03:05 PM
