Thread: car keeps dying
Results 1 to 9 of 9
  1. car keeps dying
    Jun 2008
    My passat takes notions to start first time sometimes wen I turn the key the car will start then dieit only happens sometimes anyone any ideas wat it could be
  2. Re: car keeps dying
    Norfolk
    It's usually an immobiliser problem. Get a fault code read.
  3. Re: car keeps dying
    Jun 2008
    I would only the plug is faulty and the code reader keeps sayin error I have tried different ones and they won't read the codes
  4. Re: car keeps dying
    Norfolk
    Have you checked the fuse for the diag socket.
  5. Re: car keeps dying
    Jun 2008
    yeah martin the fuse is ok wen i plug code reader in it does wat its supposed to do then wen i try and read codes its says error have tried a few different code readers
  6. Re: car keeps dying
    Norfolk
    If you have an aftermarket stereo fitted, disconnect it and try again with a code reader.
  7. Re: car keeps dying
    Jun 2008
    ok thanx i have a dvd/tv player in will try that
  8. Re: car keeps dying
    Jun 2008
    did as you said and it let me check for codes and said there was no codes which i dont get as my airbag light is on maybe take it to a mate that has the snap on reader
  9. Re: car keeps dying
    Norfolk
    Hand held code readers often struggle with airbags. A cheap ebay lead with vag-com 409.1 is better. The snap-on scanner should give you a clue.
  1. What was your first car?????
    By RickT in forum Chat - Anything with wheels
    Last Post: 06-02-2013, 12:50 AM
  2. Please Help Vibrating/shaking car
    By cayod5 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-04-2011, 02:25 AM
  3. Replies: 58
    Last Post: 01-03-2011, 09:46 PM
  4. Please Help Car switched from Long Life to Time / Distance service by accident?!?
    By wookiee in forum Golf MK5 - 2004 - 2009
    Last Post: 18-07-2010, 11:25 PM
  5. "How To" The FAQ & How To Thread
    By Ben in forum General
