Thread: Spare Wheel Question
  1. Spare Wheel Question
    Jul 2009
    Northern Ireland
    Morning All
    Sorry for the boring thread but I need a question answered.
    I'm getting one of my front wheels refurbed (already!) next week, and was intending to put the spare 'get you home' wheel on for a couple of days of light driving.
    The chap in the wheel refurb place said I should put the spare on the back axle, and use one of the 'proper' wheels on the front. He explained that the A4 would always think it was turning, and I could wreck my diff.
    Could he be right? Surely Audi would have designed a spare that could be used safely on either axle?
    Any advice gratefully received.
    '09 2.7 S line, Lava, 19's, B&O, lots of other stuff, and a ridiculously out of date user name
  2. Re: Spare Wheel Question
    May 2009
    Camberley UK
    Although the manual has nothing specific about which axle to put it on in normal use, it does say to put it on the rear if using snow chains.
    It makes sense to me to do as he says on a fwd drive generally, after all the torque/power will be transmitted through it.
    The manual does suggest temporary use over short distances, does your 'light driving' fall into this definition?
    59 Plate A4 Avant S-Line Exec 2.0tdi|Garnet Red|multi box|tech pack|tow bar|Piano Black|folding mirrors|rear park|int light|storage|DAB|hill hold
  3. Re: Spare Wheel Question
    Jul 2009
    Northern Ireland
    Yea will be very short distances until I get the alloy back. Suppose it does make sense.
    Just concerned about the possibility of damage, there will no doubt be times when the spare will be needed for the front, and it will not be practical to change wheels from the rear.
  4. Re: Spare Wheel Question
    May 2009
    Camberley UK
    Clearly in normal (non snow chain) conditions the emergency spare can be fitted in any position temporarily, otherwise Audi would have to say so.
    I would suggest that if you fulfil the conditions stated of temp use over short distances then no damage will result and if any did, and you could show compliance with their owners manual then any damage should be paid for by Audi. Proving compliance might be difficult, however.
  5. Re: Spare Wheel Question
    Nov 2010
    Yorks, UK
    Make a chalk mark on the very edge of the tyre.
    Roll it until that mark touches the ground and mark the ground where it touches.
    Roll the wheel in a straight line for 1 full revolution until the chalk mark on the tyre touches the ground again. Mark the ground again. Measure between the marks.
    Do the same with the other wheel.
    If both distances are the same, the diff will not be harmed.
    But be aware that grip will be different so the car will not handle, brake or accelerate as well as it would with 4 equal tyres
  1. Question Gt tdi wheel noise HELP (long story)
    By Buzzoff in forum Golf MK5 - 2004 - 2009
    Last Post: 06-10-2013, 06:14 AM
  2. Had cruise control fitted today.
    By paulr130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 09:42 PM
  3. Please Help spare wheel carrier
    By vwsharan in forum Touran - Sharan - Caravelle
    Last Post: 01-12-2009, 12:05 PM
  4. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  5. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
