Thread: PD fuel filter change?
  1. PD fuel filter change?
    Jan 2006
    Near Basingstoke
    Need to change mine as it has done 30K and as per other post car is not running well. However I have heard that once changed I should not keep cranking the engine to prime it, I should prime it first. Any suggestions as to how. I have a large 50 ml syringe, but that's about all for 'sucking'
  2. Re: PD fuel filter change?
    Apr 2009
    Fill the filter with diesel using the syringe.
    You can syphon it outta the tank, or put
    a few litres in a can at the pumps, its
    very good for cleaning engine parts.
    Regards
    Jim
  3. Re: PD fuel filter change?
    Co Durham
    Turn the ignition on, you should hear the fuel pump in the tank running for a few seconds. When it stops, turn the ignition off, then back on until the pump stops again. Repeat half a dozen or so times. This will fill your fuel filter.
  1. "How To" Passat B5.5 TDI Servicing
    By Col in forum Volkswagen
    Last Post: 02-05-2015, 04:11 AM
  2. Replies: 2
    Last Post: 24-11-2010, 11:35 PM
  3. "How To" 2.0 PD 140 Passat B6 Fuel Filter Change
    By DSG4ME in forum Volkswagen
    Last Post: 19-08-2010, 01:03 AM
  4. Change fuel filter
    By vroooOOOM in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-07-2009, 02:12 PM
  5. How do i change the fuel filter 2004 Golf 2.0 TDI
    By daveaustin in forum Archive posts
    Last Post: 17-04-2007, 11:36 PM
