Thread: DMF & clutch replacement
  1. DMF & clutch replacement
    Aug 2007
    BOLTON
    Hi all
    Just bought new luks DMF and clutch kit with slave cylinder for my passat 2.0 tdi sport.Just a couple of questions.
    Will I need new bolts or can they be reused because I can't find any supplied or do you have to buy them separately.
    Is the release bearing included in the clutch kit or will that be a separate item. Was told it was included but can't find it is it attached to clutch already
  2. Re: DMF & clutch replacement
    Jan 2010
    Lisburn, United Kingdom
    Make sure you replace the 6 bolts thy hold your CV joint onto the gear box. Long start short, after my DMF and clutch were changed, the bolts weren't replaced with new ones and I ended up with a hole in the gear box!
  3. Re: DMF & clutch replacement
    Norfolk
    You need to buy the release bearing as an extra. The DMF should have the clutch assembled on it. The kit should contain new DMF to flywheel bolts.
  4. Re: DMF & clutch replacement
    Aug 2007
    BOLTON
    It came in three boxes
    clutch
    DMF
    Slave cylinder
    No bolts
    Got it from my local motor factors £500
    When I phoned he said bearing was included already attached
    Or something along them lines is this possible.
    Can I not use the bolts twice
    Any help appreciated don't want to
    Turn up at the garage with half the parts
    Ps what does the release bearing look like
  5. Re: DMF & clutch replacement
    f33nix Guest
  6. Re: DMF & clutch replacement
    Aug 2007
    BOLTON
    Is the slave cylinder and release
    Bearing one item
  7. Re: DMF & clutch replacement
    Norfolk
    Yes on 2.0 the slave cylinder and release bearing are all in one. Why did you not buy the DMF/clutch complete unit. It is easier to fit and comes with the bolts for fitting it.
  1. Clutch / DMF time
    By A1Dan75 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-09-2010, 10:07 AM
  2. Question Clutch fail after Cambelt replacement and MOT at Audi garage
    By clivethegadget in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-05-2010, 08:46 PM
  3. Question Clutch and DMF Replacement
    By elPaulio in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-02-2010, 10:07 PM
  4. Clutch and DMF
    By ali_a4_avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-10-2009, 09:50 AM
  5. Replies: 2
    Last Post: 11-05-2007, 12:30 PM
