Thread: A8 3.0tdi 2005 broken timing chain tensioner
  1. A8 3.0tdi 2005 broken timing chain tensioner
    Jul 2010
    birmingham
    hi im a mechanic working for an independant garage and just had a A8 3.0tdi quattro with only 40k on the clock and will not start the code 16725 camshaft signal implausible is logged. the customer had taken it to some audi specialist who said there is a problem with the cam timing due to a chain problem.On recieving the vehicle and chatting to customer ascertained that the cam sensor had been changed and wiring checked.
    Knowing what goes on in certain workshops i decided to recheck the wiring and when i saw that the tamperproof metal bracket on the ecu had not been removed i knew it was unlikely the wiring had been checked properly.i found no problem with the wiring and decided to remove the engine to check the cam timing.Working alone with no workshop manuals at hand and no experience on this vehicle or engine but still managed to remove the
    engine,gearbox,cradle,driveshafts,hubs and wiring as a unit in 6 hours.
    Finally got to the nitty gritty after removing both rear cam covers and saw that the left hand bank chain guide had broken causing the chain to be slack and advancing the timing on that cam.(the tensioner and guide are one unit)
    thats as far as i have got with it so far and now have to remove the gearbox,flywheel and rear timing chain cover to check for foriegn objects and if any other parts of the chain drive has been damaged before i price up the parts at audi.I am surprised to see this sort of problem on a vehicle with such low mileage
    The question i would like to ask is this a common problem with this engine?
    Do other Audi chain driven engines have this problem?
  2. Re: A8 3.0tdi 2005 broken timing chain tensioner
    Apr 2010
    assen Holland
    they are known to have problems with the chain tensioner, the design was altered later and thats supposed to be fixed now. I believe all the V6 diesels have it as a rattle when starting..mine does too
  3. Re: A8 3.0tdi 2005 broken timing chain tensioner
    Jul 2010
    birmingham
    the new tensioners/guides have a different material on the guides than the original ones
  1. Replies: 7
    Last Post: 12-05-2016, 01:50 AM
  2. Chain tensioner
    By nskeates in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-03-2011, 02:17 PM
  3. Audi plays the long game with latest a8 saloon
    Last Post: 02-05-2010, 05:16 PM
  4. How To 94 TDI 1.9 Timing belt tensioner replacement
    By wells01 in forum 80 - 90
    Last Post: 21-05-2009, 09:49 PM
  5. timing chain data for fitting new chain
    By stephen gal in forum Ibiza - Cordoba
    Last Post: 26-05-2008, 03:17 AM
