Thread: Glow Plug Change
  1. Glow Plug Change
    Dunc B Guest
    I'll appreciate your thoughts & advices please.
    My Feb '04 2.5TDi Avant (2WD) has just racked up 93k miles & I think that this cold winter has alomost killed the glow plugs.
    After 2+ days of non-use the plug light now takes several seconds to go out & then the engine fires reluctantly, is very rattley (yes, I know it's a diesel ) & is very smokey.
    Does all of the above sound like knackered glow-plugs & if so any idea how much I should budget for getting them changed? Doing them myself is not an option - mainly due to my mechanical incompetence!
    Thanks.
    Dunc.
  2. Re: Glow Plug Change
    May 2010
    Croydon
    What colour is the smoke and are you using any fluids?
    Does the rough running improve when it's up to temp?
  3. Re: Glow Plug Change
    Southern County Softy
    20 Post(s)
    The plugs are well known to break in the head when being removed.
    they should be soaked in plus gas a couple of days before removal.
    Give the garage the heads up when you take it in !!
    A4 2.5 tdi QS (mapped)
  4. Re: Glow Plug Change
    Jan 2009
    Birmingham
    36 Post(s)
    First thing to check is if you got ceramic plugs or metal ones metal are easy to change but ceramic ones you got to be careful you don't crack them so before you buy just find out what is fitted to your car I thing the metal ones have a red ring on the top but not 100% sure
  1. Question Glow Plug - VAG Info
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-12-2011, 07:36 PM
  2. 3.0tdi glow plug light only on for 1 sec.
    By sparker in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-12-2010, 08:54 PM
  3. Please Help No glow plug power - 1.9TDi
    By DubDick in forum Golf MK3 - 1993 - 1999
    Last Post: 24-10-2010, 12:39 PM
  4. glow plug change?
    By t4 animal in forum Archive posts
    Last Post: 13-11-2007, 11:45 AM
  5. A3 TDi glow plug problem
    By dubiousmaximus in forum Audi A3 - Archive Topics
    Last Post: 28-06-2007, 07:15 PM
