Thread: Tailgate handle not working...
  1. Tailgate handle not working...
    Nov 2010
    Oxfordshire
    I've tried to find similar threads on this issue, but no luck.
    I have a 2000 S4 Estate and the touch pads by the number plate lights have recently stopped working. The Key fob still releases and you can open it using the key in the lock.
    To start with the left hand pad didn't work, but the right did, then a couple of weeks ago the right packed up too.
    The lock was bunged up with road salt, but I freed this with WD40.
    The internal mechanism all sounds fine when opened with the key fob and there haven't been any issues with closing it or central locking.
    I wondered if the handle has a separate fuse that might have blown?
    Any other ideas?
  2. Re: Tailgate handle not working...
    Birmingham
    7 Post(s)
    If it is a soft touch one, ie a small micro switch which operates a solenoid on the lock the switches pack up due to age and use. If it does have them try shorting the wires across on the switch and it should open it up.
  3. Re: Tailgate handle not working...
    Nov 2010
    Oxfordshire
    It is the soft touch one, you can hear the switch 'clicking' when you press the surface, but nothing happens, hence having to open using the key or the fob button.
    Any idea what I have to get to replace/repair it?
  4. Re: Tailgate handle not working...
    Birmingham
    7 Post(s)
    The switches are the normal thing to go. On mine you have to take off the inner panel on the bootlid and remove the lock assembly. Or if you can get to the switches or wires to them try just bridging it to see if the release solenoid energises. If it does then it will be the switch. I would say it is a dealer only part but not to expensive i would imagine. If it still does not work by shorting the wires together then check for a 12 volt supply. If you dont have that check for broken wires in the boots between the tailgate and the body of the car. Let me know how you get on.
  5. Re: Tailgate handle not working...
    Nov 2010
    Oxfordshire
    Thanks, I'll have a look at the weekend...
  1. B8 Avant tailgate doesn't open by the handle
    By MHAD in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-11-2010, 10:34 PM
  2. Passat B5 door handle
    By barry1066 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2010, 09:41 PM
  3. Please Help Estate tailgate lock problem
    By jaywalker in forum Golf MK3 - 1993 - 1999
    Last Post: 12-10-2009, 11:34 PM
  4. Replies: 3
    Last Post: 12-06-2009, 08:12 PM
  5. Golf mk4 tailgate cental locking not working.
    By Rayfaedundee in forum Archive posts
    Last Post: 10-09-2007, 11:44 PM
