Thread: Dpf
  1. Question Dpf
    Dec 2010
    Aberdeen
    is this a common problem to play up?
    My 3.0 has done just over 34K miles (I've just bought it so someone else's running) and the glo plug warning started to flash the other day when I started it. It went out after a few miles but it ran like a pig until then.
    Was told by the local dealer to run it at 40ish, 2500rpm for 10 minutes or so to recharge it.
    Will this be a recurring problem??
  2. Re: Dpf
    Jul 2008
    Essex, United Kingdom
    First of all, dpfs are fitted onto all diesels that go into production now as they remove the smoke from the exhaust that would otherwise go into the air (the "particulates"). Doesnt matter if you have a BMW, Audi, Skoda etc..they all have to have it.
    The DPF basically fills up with the particulate soot, and burns it off when your engine gets hot and is used on long runs. If you are driving around town mostly (i.e. start/stop traffic, less than 30mph average) then the DPF fills up and you'll need to take it for a run to burn it all off.
    In answer to your question...if you use it around town mostly and short runs, then yes it will be a recurring situation for you because the engine needs to be run in 4th/5th gear at 2000rpm+ for about 10 minutes to burn it off. I think on average this will only be once every 600-900 miles though.
    Simple solution is just to take it out for a blast on some dual carriageways/motorways every now and then just to get it nice and hot and burning off.
    Just a tip though...don't ignore the warning light when it does come on the dash. The DPF continues to fill up with soot..and if it goes over a certain level you have to take it back to the dealer to get it regenerated which can potentially cost you money.
    Hope this helps,
    -Andrew
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. XP - Very Slow on Start up...
    By RickT in forum Home Tech Shed
    Last Post: 16-08-2010, 05:56 PM
  3. Diesel Particulate Filter on Engine BMK
    By Leoflavio in forum Phaeton
    Last Post: 10-05-2010, 12:33 PM
  4. Trim Confusion
    By ocelot0411 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2009, 11:16 AM
  5. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
