Thread: Knocking noise
  1. Smile Knocking noise
    May 2010
    birkenhead
    Coming off the trottle im gettin a knocking noise- at this stage i dont have alot of information to tell you other than a visual check showed nothing obvious was loose! Its a 98 a3 1.8 turbo agu engine- anyone had engine mount problems or found the upgraded aftermarket mounts to be good? Maybe going off track here but on start up if you get a knock is that a flywheel problem?
  2. Re: Knocking noise
    Mar 2010
    Lincoln
    Hi mate, Maybe you should let your mother-in-law out of the boot,
    sorry, no help i know
  3. Thumbs up Re: Knocking noise
    May 2010
    birkenhead
    Good to know some people on here have a sense of humour! Haha, no worries mate- been through a tough time with this car and hoping it isnt more major work!
  4. Re: Knocking noise
    Mar 2010
    Lincoln
    Hope you get sorted mate, My throttle body was cleaned yesterday as it was cutting out when i slow down, Audi had a go at setting it but did not work, now it idles at 1500-2000 revs. Got a new throttle body today from gsf & hopefully get fitted tomorrow. Good luck with yours. Pete
  5. Re: Knocking noise
    May 2010
    birkenhead
    Cheers mate, still no closer to finding what it is- hope urs is better now
  6. Re: Knocking noise
    Mar 2010
    Lincoln
    Hi mate, New thottle body fitted & set up, But now the pedal is as stiff as hell, I don`t know if the cable as been fitted right or not.
  1. Question Gt tdi wheel noise HELP (long story)
    By Buzzoff in forum Golf MK5 - 2004 - 2009
    Last Post: 06-10-2013, 06:14 AM
  2. A4 1.8 B5 Knocking noise after timing-belt done
    By sanstorm999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-08-2011, 06:35 PM
  3. Audi A3 TDI 130 Knocking noise
    By r3ahj in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-02-2011, 10:28 PM
  4. help please knocking noise Reward!!!
    By roy2001 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-06-2010, 11:13 PM
  5. VWT4 1999 Auto 2.5tdi. Knocking noise...
    By pblucas in forum The Commercial Range
    Last Post: 06-10-2009, 04:26 PM
