Thread: Brake piston rewind tool ??
  1. Brake piston rewind tool ??
    Mar 2008
    Warminster
    Will this one be ok for my 2001 a6 tdi
    cheers guys
    http://cgi.ebay.co.uk/Brake-Piston-R...item2c5a746b97
  2. Re: Brake piston rewind tool ??
    May 2010
    Devon England
    if its for your rear pads then yes it is if you want to do the fronts you will need a flat adaptor to push it back
  3. Re: Brake piston rewind tool ??
    Mar 2008
    Warminster
    Cheers,
    is it only the rears that screw in and the fronts are straight forward push in
  4. Re: Brake piston rewind tool ??
    Mar 2008
    High Wycombe
    That's right - the front's push in, the rears need screwing in because of the handbrake auto adjuster.
    Before you order it from ebay, check the price at your local car accesories shop - they're often as cheap once you've accounted for postage etc. (I can't view ebay from work so I can't check the price of the one you'velinked to)
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  5. Re: Brake piston rewind tool ??
    Mar 2008
    Warminster
    I already ordered it, it was £13.90 delivered so not so bad and came today.
  6. Re: Brake piston rewind tool ??
    Jan 2010
    Hull
    Not a bad price, it work ok?
  7. Re: Brake piston rewind tool ??
    Dec 2010
    keighley west yorkshire United Kingdom
    i ended up making my own from a spare cheap socket and 2 bits of metel welded to it, had to use it twice and it works a treat lol
  1. Please Help Brake Piston Question on Replacing rear discs
    By muchos04 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-08-2009, 07:31 PM
  2. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  3. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  4. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  5. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
