Thread: shaking when at a standstill
Results 1 to 10 of 11
  1. shaking when at a standstill
    Jan 2011
    Sheffield/Grimsby
    Hi , i am a new member and this is my first post.
    I've just purchased a 2003 A4 1.9tdi quattro, and when the engine is warm it seems to shake when at a standstill. It's ok when the engine is cold and pressing the clutch makes no difference! It has full Audi main dealer service history.
    Is this normal ?
    many thanks
    mick
  2. Re: shaking when at a standstill
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    Quote Originally Posted by yorkimick View Post
    Is this normal ?
    many thanks
    mick
    Define "shake"? Do you mean it's idling roughly or too low-revs when warm but it's fine when it's cold?
    Cheers,
    Dan.
  3. Re: shaking when at a standstill
    Jan 2011
    Sheffield/Grimsby
    It's when its warm and on tickover at a standstill. The car just shakes as if its about to stall?
    mick
  4. Re: shaking when at a standstill
    You need to have a fault code read to find out what is going on
  5. Re: shaking when at a standstill
    Sep 2008
    6 Post(s)
    mick
    Look at the rev gauge to see what the engine is doing. Could be any number of things, split vacuum pipe, clogged fuel filter, blocked injector, etc.
    2016 BMW i3 REx (80k)
  6. Re: shaking when at a standstill
    Jan 2011
    Sheffield/Grimsby
    I have had the car checked and its showing no faults. Had it serviced sat and new fuel filter fitted and injector cleaner .
    Regards
    Mick
  7. Re: shaking when at a standstill
    did that fix it or not?
  8. Re: shaking when at a standstill
    Dec 2009
    southampton uk
    Does it have active engine mounts?
  9. Thumbs down Re: shaking when at a standstill
    Jan 2011
    Sheffield/Grimsby
    No it didnt make any difference re service and fuel filter or the injector cleaner. The mechanic checked the engine mounts and stated they were ok?
    regards
    mick
  10. Re: shaking when at a standstill
    Jul 2009
    Belgium
    try 2 times full tank with v.power diesel and may be some( forte )injector cleaner it will help i had the same problem and i used the same thing no problem any more.goed luck
  1. Engine Shaking after Cam Belt Change!!!
    By danGT in forum Golf MK5 - 2004 - 2009
    Last Post: 25-10-2014, 12:43 PM
  2. Shaking Car
    By Screedman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-10-2010, 06:48 PM
  3. Important shaking on very hot day when try moving
    By Exis in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-09-2010, 11:45 PM
  4. Please Help Shaking when warm
    By mr-nick in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-09-2009, 10:38 AM
  5. Noise/Clunk/Pause when braking to standstill
    By jamoca in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-03-2008, 11:59 PM
