Thread: 2011 CC VCDS autoscan anyone?
Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 101 to 110 of 120
  1. Re: 2011 CC VCDS autoscan anyone?
    Aug 2009
    Warrington Cheshire
    Ahh, I see. Thanks for that.
    Great car though.
  2. Re: 2011 CC VCDS autoscan anyone?
    Jul 2008
    Coventry
    Unbelievable that your dealer didn't know this.
  3. Re: 2011 CC VCDS autoscan anyone?
    Aug 2009
    Warrington Cheshire
    Doesn't give much confidence.
    Be nice if I could get it to work like your set up.
    Are these codes able to work on a 2008 model?
    Thanks again
  4. Re: 2011 CC VCDS autoscan anyone?
    Jul 2008
    Coventry
    I believe so, but to be honest I'm not really sure. If you find someone with VCDS and plug it into your car, have a look at the bits and bytes which have been referred to in this thread - if the setup is the same, they will be labelled as such.
  5. Re: 2011 CC VCDS autoscan anyone?
    Aug 2010
    Cheshire
    sorry to resurrect this old thread but I've just completed a scan and it's thrown up a couple of errors.
    The immobilisers one is related to the key which has given me a low battery warning so that explains that. However, The error code for the media system is what confuses me ...
    can anyone tell me what the coding should be?
    A printout of the scan is given below
    Friday,15,February,2013,07:36:30:39039
    VCDS Version: Release 11.11.5 (x64)
    Data version: 20121222
    Chassis Type: 7N0
    Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56
    61 62 72
    VIN:
    01-Engine -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: Malfunction 0010
    37-Navigation -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    Address 01: Engine (J623-CFGB) Labels: 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 BH HW: 03L 907 309 N
    Component: R4 2,0L EDC H24 7890
    Revision: 47H24--- Serial number: 00000000000000
    Coding: 00190012042501080000
    Shop #: WSC 00015 115 00000
    ASAM Dataset: EV_ECM20TDI01103L906018BH 003003
    ROD: EV_ECM20TDI01103L906018BH.rod
    VCID: 71C709A7A0316590DE2
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 3AA-614-109.clb
    Part No SW: 3AA 614 109 N HW: 3AA 614 109 N
    Component: J104 C2 450M VDC1 0005
    Revision: --H07--- Serial number: 00000003905352
    Coding: 0004025
    Shop #: WSC 05311 000 00000
    VCID: 3851F4834BCBF4D8D9C
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 5K0 907 044 ED HW: 5K0 907 044 ED
    Component: Climatronic H17 1010
    Revision: 00003001
    Coding: 0000000003
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_Climatronic_VW46.rod
    Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
    Part No SW: 3AA 937 087 B HW: 3AA 937 087 B
    Component: BCM PQ47 H+ 413 0452
    Revision: BC413001
    Coding: 0000000000000000009C002094008024435177884460076000 80C7200041
    VCID: 3957F187B0C1EDD0262
    Subsystem 1 - Part No SW: 3C8 955 119 E HW: 3C8 955 119 E
    Component: Wischer 05021 10 0603
    Coding: 00B795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 160311 05 54 0403
    Coding: 0330ED
    Address 10: Park/Steer Assist (J446) Labels: 3AE-919-475.clb
    Part No SW: 3AE 919 475 HW: 7N0 919 475
    Component: PARKHILFE 8K H04 0009
    Revision: -------- Serial number: 28291105529067
    Coding: 108003
    Shop #: WSC 99999 1023 2097151
    ASAM Dataset: EV_EPHVA18VW47X0000 001003
    ROD: EV_EPHVA18VW47X0000.rod
    VCID: FCD9A893777398F8FD4
    Address 14: Susp. Elect. (J250) Labels: None
    Part No SW: 3C0 907 376 A HW: 3C0 907 376
    Component: DAEMPFUNGS-SG H07 0071
    Revision: 00000000 Serial number: 23021100790001
    Coding: 010180
    Shop #: WSC 05314 000 00000
    VCID: 277327FF56756B20406
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
    Component: J234__306 VW10 HI 1918
    Revision: 22014000 Serial number: 003K0P4GY7H/
    Coding: 0012342
    VCID: 4CB9B8532F5368788D4
    Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
    Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
    Component: LENKS.MODUL 014 0140
    Revision: FF010040 Serial number: 20110307300059
    Coding: 0182270001
    ASAM Dataset: EV_VW360SteerWheelUDS A03004
    ROD: EV_VW360SteerWheelUDS_VW46.rod
    VCID: 72C506ABA5375E88278
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
    Component: E221__MFL-TK6 H06 0022
    Coding: E20000
    Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
    Part No SW: 3C8 920 970 P HW: 3C8 920 970 P
    Component: KOMBI H20 0420
    Coding: 440F01
    Shop #: WSC 05314 115 00000
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
    VCID: 3957F187B8C1EDD0262
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 D HW: 1K0 907 951
    Component: J533 Gateway H35 0614
    Revision: H35 Serial number: 240211F1002037
    Coding: 469007
    VCID: 3147C9A768B125909E2
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3AA 959 799 HW: 3AA 959 799
    Component: IMMO 083 0399
    Revision: 00083000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 052F4D774CB9593012A
    Part No: 3C0 905 861 J
    Component: ELV 029 0380
    3C0905861J ELV 029 0380
    1 Fault Found:
    01176 - Key
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 133
    Mileage: 28559 km
    Time Indication: 0
    Date: 2009.14.13
    Time: 15:54:31
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
    Component: SG EXT.PLAYER H13 0150
    Revision: A1001003 Serial number: 7669584571
    Coding: 020000
    VCID: 287124C35B6B645849C
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 233
    Mileage: 28555 km
    Time Indication: 0
    Date: 2009.14.13
    Time: 14:37:18
    Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
    Part No SW: 3C0 035 279 HW: 3C0 035 279
    Component: RNS315 H05 0010
    Serial number: VWZAZ2L3304334
    Coding: 040004110400000000011000
    ASAM Dataset: EV_RNS315VWEUV1UDS A01005
    ROD: EV_RNS315VWEUV1UDS_VW46.rod
    VCID: E0E1FCE3FBDB5C18C1C
    Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 3C8 959 701 HW: 3C0 959 793 C
    Component: TUER-SG FT 002 0502
    Revision: 12110009 Serial number: 0002442475
    Coding: 0202B5
    Shop #: WSC 05311 115 00000
    ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
    ROD: EV_TSGFPQ35BRFVW46X.rod
    VCID: EDFF95D73C0901707AA
    Slave Driver:
    Subsystem 1 - Part No SW: 3C8 959 704 C HW: 3C0 959 794 B
    Component: J389__TSG-HR 004 0401
    Serial number: 00000001969271
    Coding: 000090
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 207 3201
    Revision: 00H20000
    Shop #: WSC 02069 000 90108
    VCID: 3449C0B357A310B8F54
    Address 46: Central Conv. Labels: 3C0-959-799-46.clb
    Component: 09 KESSY PQ47 083 0323
    Coding: 01910A0001C60E763604941572005FCE107C0103241498
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H05 1501
    Part No: 3C0 951 171 C
    Component: Neigungssensor 004 0611
    Component: Innenraumueberw.004 0611
    Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
    Part No SW: 7N0 907 532 HW: 1K0 907 951
    Component: EZE_2 H35 0614
    Coding: 00000008
    VCID: EFC38FDF3E05F360486
    Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
    Component: Analoguhr 004 0003
    Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 3C8 959 702 HW: 3C0 959 792 C
    Component: TUER-SG BT 002 0502
    Revision: 14110009 Serial number: 0002387096
    Coding: 0202B4
    ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
    ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
    VCID: EEFD92DB310FFA68430
    Slave Passenger:
    Subsystem 1 - Part No SW: 3C8 959 703 C HW: 3C0 959 795 B
    Component: J388__TSG-HL 004 0401
    Serial number: 00000002000384
    Coding: 000090
    Address 53: Parking Brake Labels: 3AA-907-801.clb
    Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
    Component: J540 EPB4 VW-55183 0007
    Revision: H18 Serial number: 00000000236359
    Coding: 0022067
    VCID: 334BC3AF52AD1780ECE
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H35 0614
    Coding: 030B185A
    VCID: F1C789A72831E5905E2
    Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
    Component: J367-BDM H07 0150
    Spec Ordered: 170GT, pearlescent black, keyless, heated sceen, aircon seats, MDI
    Order confirmed on 16 September 2010
    estimated supply date: November 2010
    Actuall build date: 23 March 2011
    Collected: 4 April 2011
  6. Re: 2011 CC VCDS autoscan anyone?
    Jul 2008
    Coventry
    Greg, did you clear the codes and do a new scan, and did it come back?
  7. Re: 2011 CC VCDS autoscan anyone?
    Aug 2010
    Cheshire
    No, I've not done that yet. do you think it may have been a one-off glitch? Will try it when I get home later.
    This is the first time I've used VCDS
  8. Re: 2011 CC VCDS autoscan anyone?
    Jul 2008
    Coventry
    Yeah it's always worth clearing the fault codes after making a note/export of them to see if they return... my CC lease has now come to an end and I await a new CC for delivery on the 1st!
  9. Re: 2011 CC VCDS autoscan anyone?
    Aug 2010
    Cheshire
    Nice, i like the look of the new cc.
    Clearing the faults worked a treat cheers, just looking to have s fiddle now. Any advice is welcome!
    Sent from my GT-I9300 using Tapatalk 2
  10. Re: 2011 CC VCDS autoscan anyone?
    Jul 2008
    Coventry
    Don't think there can possibly be much more advice available than what I posted in this thread a couple of years ago. The things I changed that I think made the most difference to my experience with the car were probably (not in any order); teardrop wipe, 4 comfort blinks, heated seat setting memory for driver, DRLs, disable highway light, dials to ROW to enable big speed readout, cornering light on with reverse, windows up without holding remote button until closed, siren blip on successful anti theft alarm set, and also correction to the MPG readout having worked out the correct MPG manually (I had to set mine to 106%).
  1. A6 C6 VCDS Changes - Post & Pre Facelift
    By MFGF in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-11-2022, 09:33 PM
  2. Please Help Do You have VCDS
    By martin1810 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-01-2014, 11:17 AM
  3. Ultimate Dubs uk 13th March 2011
    By ozzit in forum Shows & Events
    Last Post: 09-12-2010, 10:20 PM
  4. VCDS OR VAG CAN Commander
    By Tariq Malik in forum VCDS - Help Requests
    Last Post: 12-03-2010, 03:02 PM
