Thread: Help Car wont Start
Results 1 to 10 of 13
  1. Smile Help Car wont Start Now Does
    Otley West Yorks
    HELP:
    Just come to start my A3 2.0 TDI when put key in thought I heard a metallic knock " 07:00am minus 4 "
    When tried to start it engine turns over but does not try to fire
    I have just noticed that oil light flashes when finished trying to start it ?
    Wife drove it last night but did not Notice anything and said it drove OK!!!!!!!
    Checked Oil seems OK Car has done 43000 miles no problems to date
    Any Ideas before contacting Dealers to Tow in
    Just a thought does the engine immobiliser stop it from starting or turning over ?
  2. Re: Help Car wont Start
    The immo will not stop the engine from turning over,it will start, only to stop again after a few seconds,i'am wondering if something has happened with the glow plug function,the oil light flashing is normal when the engine has been crancked and will not start think maybe you need a fault code read
  3. Re: Help Car wont Start
    Otley West Yorks
    Quote Originally Posted by kenney View Post
    Thanks just found the imo info
    Just found a local guy to come round with computer
  4. Re: Help Car wont Start
    check fuse 9 and fuse 51 on the fuse holder
  5. Re: Help Car wont Start
    Otley West Yorks
    Just had it checked but only on hand held computer shows no fault codes so that rules out any electrical faults
    The mech suspects high preasure fuel pump but with out car in workshop can not check pressure
  6. Re: Help Car wont Start
    Can you hear the fuel pump,when you turn the ignition on?,even if there was something wrong with the high pressure pump,at the first attempt to start the engine would have started,and stopped again
  7. Re: Help Car wont Start
    Otley West Yorks
    The mech who came out only a lad took the fuel pipe off the filter and i turned the ignition on and fule came out
    That what made hime think of the the high pressure Pump
    But did not sound convincing
    When I tried to start it this morning it Did Not fire at all just spun over ?
    The local Garage is a VAG repairer but has diagnostic
    But can not do High Pressure Dieslel testing
    He would have to change the pump and see!!!
  8. Re: Help Car wont Start
    Do you notice a different speed on turnover of the engine,when trying to start it?
  9. Re: Help Car wont Start
    Otley West Yorks
    No just same as normal but fires at first turn
    Were is fuse 51 found 9 in engine bay fuse box but only goes to 29
    F9 in engine bay is either sat nav or engine components depending on fuse box
    Mine is 2ltr TDI but only has the 32 fuses fiited
  10. Re: Help Car wont Start
    There are 2 types of fuse boxes high box and low box and they vary according to year and engine code,looking at the options,the low box has 30 fuses and fuse 27 is for glow plugs,the high box has 54 and fuse 51 is for the glow plugs
  1. Replies: 58
    Last Post: 01-03-2011, 09:46 PM
  2. 1.8T Common Troubleshooting Guide
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2010, 12:17 AM
  3. Damm Laguna
    By Lex_Andrews in forum Chat - Anything with wheels
    Last Post: 08-05-2010, 11:17 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Audi Ancestor Could Be Most Expensive Auctioned Car Ever
    Last Post: 04-02-2007, 07:12 PM
