Thread: Where's my Thermostat? Passat TDi 130 avf.
Results 1 to 8 of 8
  1. Question Where's my Thermostat? Passat TDi 130 avf.
    Feb 2007
    Flint, N.Wales
    Help required in finding my Thermostat on Passat TDi 130 (2001) Engine code AVF. Where abouts, front; left side; right side; behind engine, Any body got any pictures, also correct part number please as euro car parts seem to have 2 that are supposed to fit but they look different from one another.
    Thanks in advance for any help.
  2. Re: Where's my Thermostat? Passat TDi 130 avf.
    On the engine block behind and below the alternator
  3. Re: Where's my Thermostat? Passat TDi 130 avf.
    Do yourself a favour and go and get a stat from VW dealer and the G12++ coolant. Regards Peter
  4. Re: Where's my Thermostat? Passat TDi 130 avf.
    Dec 2007
    wigan
    the alternator has to be removed does it..?
  5. Re: Where's my Thermostat? Passat TDi 130 avf.
    Gwent
    Quote Originally Posted by passat tdi130 View Post
    No need to remove alternator, just follow the bottom hose back from the rad, where it joins the block is a moulded plastic flanged hose fitting, the thermostat is under it.
    the bolts are 7mm thread which is unusual, so don't drop them....
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  6. Re: Where's my Thermostat? Passat TDi 130 avf.
    Chipped2 Guest
    I have a 2002 Passat Sport PD 130 Estate with AVF engine and asked the same question on 29-3-2011 as I was unable to find my G62 sensor after several attempts.
    The answer was provided by Crasher who included an excellent photograph. Go back three pages and find it.
    The parts you need are;
    059919501A - G62 temperature sender................£28.28 + vat
    N90316802 - O Ring............................................£ 1.03 + vat
    ????????????- Plastic retaining clip.......................£ .55 + vat
    The new one is brass/green plastic. Original is black
    Can be bought off ebay for £7/8 complete but my advice is to buy VW too.
    Get a small mirror and torch to locate it. It is between the bulkhead and back of the engine on the drivers side and plugs into an alloy boss on the engine. The boss points to the rear of the car. The sensor plugs into it at right angles and points to the offside as the picture shows.
    My plastic retaining clip pointed upwards and the two prongs can be seen in the slots from above. There is no need to disturb alternator whish is on the opposite side anyway. It is approached from the drivers side.
    I found it easier to remove the first knuckle from the air cleaner to intercooler pipe that runs between engine and bulkhead after removing the engine cover and the smaller cover screwed to the exhaust manifold heatshield etc. Release pressure in header tank but replace cap.
    Fit o-ring to sensor in readiness. Unplug connector from old sensor tying up out of the way. as it get covered in antifreeze. Remove retaining clip downwards holding old sensor in place. Have a tapered wine cork ready that fits O-ring.......remove old sensor complete with original O-ring and replace with new sensor/ring checking that the old ring is removed .
    Alternatively use the cork to stem the flow of antifreeze to give time to line up the new sensor/ring in readiness. The removed cork will probably pull out the old ring....but again check.
    Hold the new sensor in place while.....re-fitting plastic sensor retaining clip from beneath into the sensor housing holes ensuring that the two 'pins' are visible on the top. Wash off all spilt antifreeze. Replace dry plug. Top up header tank. You will probably have only lost a few mm of antifreeze.
    Refit turbo pipes ensuring all the small bore pipes are plugged-in where they shold be. Replace engine covers.
    Don't damage the black foam around the cam-cover as they cost over ....£50
  7. Re: Where's my Thermostat? Passat TDi 130 avf.
    Dec 2007
    wigan
    wrong stat bud thats the coolant temp sensor for gauge and ecu..!
    Passat Tdi 130 Sport
    Audi RS4 alloys polished alloy fronts
    no mod's
  8. Re: Where's my Thermostat? Passat TDi 130 avf.
    Chipped2 Guest
    If you don't ask the right question.....bud?..... you won't always get the right answer.
    After market guys usually have two different parts...one that fits...........!
  1. Passat estate 1.9 tdi 130 sport or A6 130 tdi estate, advice please?
    By openside in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-10-2013, 11:40 PM
  2. Passat estate 1.9 tdi 130 sport or A6 130 tdi estate, advice please?
    By openside in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-01-2010, 10:05 PM
  3. My first impressions of my GT TDi Golf
    By james_tiger_woo in forum Golf MK6 - 2009 - 2013
    Last Post: 30-06-2009, 05:42 PM
  4. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  5. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
