Thread: fault code 005659
Results 1 to 10 of 10
  1. Post fault code 005659
    Dec 2010
    manchester
    Hi guys,
    this is the engine fault code i have got on passat 2005 1.9 tdi
    1 Fault Found
    005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
    P161B - 000 - -
    Freeze Frame:
    Fault Status: 01110000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 105432 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 23:58:12
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.08 V
    Bin. Bits: 11000000
    Temperature: -0.9°C
    Bin. Bits: 00110000
    How serious is this glow plug fault?? how much approximately am i lookin at to get it sorted?? please help. the car starts and run fine..no probs at all.
    thanks
  2. Re: fault code 005659
    Nov 2008
    SE Northumberland
    Prob`ly just a duff glow plug. I had one go and replaced all four keeping the three good ones as spares.Paid about £60 from VW. Originally got some cheap from GSF that were the wrong voltage and all four went as soon as I turned the car on. Lesson learned, always go OE if cost allows. 2.0 Tdi involves a bit of dismantling to get at the plugs, not too difficult though. Dunno about the 1.9.
  3. Re: fault code 005659
    Norfolk
    Ignore it. Clear the code and see if it comes back in a weeks time. This code does not mean you have a faulty glowplug. It simply means one plug failed the start up routine test once. It may well have been due to the battery voltage being a bit low.
  4. Smile Re: fault code 005659
    Dec 2010
    manchester
    thanks martin, will try that.
  5. Re: fault code 005659
    Oct 2010
    portsmouth
    just going to bump this, i have the same problem, firstly engine management came on with engine start up (no warnings or messages) went to garage, injector/glow plug loom replaced, month or so later same again,scan open curcuit cylinder 3 glow plug so this time all 4 glow plugs were replaced, two days later same again, scan said open circuit glow plug cylinder 3.
    fault cleared and been ok for week or 2 now.
    its going in to independant in a hour for further checks to see the route of the problem, did anyone have an outcome?
    07 passat estate 2.0 TDI sport
  6. Re: fault code 005659
    Norfolk
    Have the garage been fitting the correct NGK glowplugs. If not the glowplug controller will fail.
  7. Re: fault code 005659
    Oct 2010
    portsmouth
    invoice reads NGK9835
  8. Re: fault code 005659
    Norfolk
    I would ask the garage what "NGK9835" means. The correct glowplug for most 2.0 PD engines is NGK CZ304 (order No. 9864). BMP and BVD engines use NGK CZ104 (order No. 9826).
    I don't know what a "NGK9835". Sounds like you may have the wrong glowplugs fitted and the controller won't like that. What engine code is your car.
  9. Re: fault code 005659
    Oct 2010
    portsmouth
    mine is the bkp engine, checked your site which seems the correct plugs, the fault has been intermitent before the plugs were changed. (great site you have there btw)
    just typed ngk9835 into google and got me this http://www.opieoils.co.uk/p-63926-ng...-ref-9835.aspx
  10. Re: fault code 005659
    Oct 2010
    portsmouth
    just bumping this again. so last time the garage checked all wiring and control module etc. . . found a contact fault and replaced a multiplug connector at the end of the wiring harness. now this was on the 11/1/2012 at 109666miles, now yesterday it came on again yesterday morningat about 110200ish. have not code read it yet but its happened the exact same way as before on start up.
    its starting to become a pain in my a***
  1. Decoding error codes Help!!
    By charbel89 in forum VCDS - General Questions
    Last Post: 17-09-2010, 09:40 AM
  2. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  3. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  4. gearbox isolator switch??????
    By a25c in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-11-2009, 11:29 PM
