Thread: CD player.
  1. CD player.
    S.E / Kent
    Hi guys, I recently played a CD-R disc and since then the machine will not read any of the 6 discs. A message comes up as CD error. Will an ordinary cd cleaning kit sort this problem out? Thanks, redman
    banbury,oxon
    it might do.....are any of the other disks CD-R????reason i ask is CD-R disks are slightly thicker
    lee
    B5 passat needs a supercharger and does'nt leak
  3. Cd player.
    S.E / Kent
    Thanks for the reply. The other cd's are the ordinary music cd's and non of them will play .... same error message.
    Quote Originally Posted by redman View Post
    if youve played a cd slightly thicker than the reccomended thickness, there is a chance you could have 'skimmed' the laser eye, causing it to not be able to read them, if i were you, double check the cds your using actually play in a normal hifi, then try them in your car, if they dont work in the car, you may have to have the head unit repaired.
  5. cd player
    S.E / Kent
    Thanks eshrule. Sorry for the delay. I was away for a while. Tested the cd's on my home hi-fi, and they were ok. I have a gamma v head unit with a 6 cd thing behind in the boot. Which one of these needs to be repaired?
    Thanks,
    redman.
  1. CD Player not working.
    By Oddball in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-05-2007, 04:36 PM
  2. Cd Player Problems
    By ijado1981 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-05-2007, 01:33 PM
  3. cd player
    By italianrat182 in forum Audi A3 - Archive Topics
    Last Post: 14-04-2007, 09:45 AM
  4. CD player
    By Brianm in forum Archive posts
    Last Post: 06-12-2006, 10:21 PM
  5. Is this any good (DVD Player)
    By Whitie in forum Chat - Completely Off Topic
    Last Post: 08-02-2005, 01:20 PM
