Thread: Headlight upgrade
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: Headlight upgrade
    Oct 2009
    York
    Quote Originally Posted by Bratty View Post
    Yep still available, just the headlights though (modules were swapped onto my LHD ones)
    Dunk
    Awesome!!!!
    How much are you looking for them and seeng you seem to be experienced in all this, what else do I need for the conversion (forgetting about the washers and auto-levelling)
    Cant PM due to my low post cound (only got my 60plate A4 last week ) so you can e-mail me at ianc1990@gmail.com if its any better.
    Thanks!!!
  2. Re: Headlight upgrade
    Bratty Guest
    Quote Originally Posted by ianc1990 View Post
    Awesome!!!!
    Thanks!!!
    Hi matey you can have the pair for 150 pounds (if you pay the postage from Germany), they are of no use to me, and I would prefer that a Member of the Forum got them, so that we might get some positive feedback on the conversion.
    Dunk
  3. Re: Headlight upgrade
    Oct 2009
    York
    Ok guys
    So Im getting the headlights from Duncan.....
    Can anyone else list what I need for the conversion?
    Im guessing 2 bulbs, 2 Xenon ballasts, 2 LED ballasts and the kufatek loom....
    Can anyone think of any cheap ways to get hold of any of these and is this all I need?
    Ian
  4. Re: Headlight upgrade
    Oct 2009
    York
    Ok guys
    Ian
    Basically, is this kit all I need (apart from the kufatec loom)? (and is that a good price?)
  5. Re: Headlight upgrade
    Bratty Guest
    Ian, There is one (OEM) xenon bulb with the lights.
    Dunk
  6. Re: Headlight upgrade
    Oct 2009
    York
    Yep Duncan - its just so I dont confuse too many people on here
    Do you know the part number of the bulb so I can order a like for like at the dealers here. Dont want to get one that burns at a different kelvin rating!!
    Also, is this what they call a D3S system?
    Thanks!
  7. Re: Headlight upgrade
    #17
    Oct 2009
    York
    Ok,
    So im nearly there now - the headlights should hopefully be with me today or on Monday....
    The kufatec loom I expect Monday/Tuesday then the ballasts sometime next week....
    My question is - how do I route the cabling for the Kufatec loom? Does anyone know where I can get through the firewall to get to the CECM and does anyone know where the CECM is on this car? Kufatec has I guide which i just spent an hour translating but this is for LHD cars so I dont know where the hell the CECM is(i'm expecting drivers footwell) or where to route the cabling to get to it!
    Help on this is really appreciated!
  8. Re: Headlight upgrade
    #18
    Berkshire
    Rather than go to all of this aggro, why not just fit some high end Xenon bulbs like Phillips Extreme. These are supposed to only be a tiny bit worse than the BI Xenons.
  9. Re: Headlight upgrade
    #19
    Oct 2009
    York
    Well that would certainly be the easy way of doing things
    I personally like coding/wiring/messing so its an awesome challenge for me! The plus side is that I managed to get the parts for very little money!
    I was also mainly after the LED DRL's rather than the type of bulb because as you said, they aint that different.
  10. Re: Headlight upgrade
    #20
    Oct 2009
    York
    Digging this back up but FINALLY I have received my bulbs and ballasts from america and fitted the lights yesterday (in pitch black darkness seeing its dark by 5am now
    I have a little problem and I am really hoping that someone can help me out with this, because I will have to swap them back out if I cant
    Lights are fitted, and everything is working well. I haven't yet routed the high beam wires into the CECM so I know that this comes up as an error and high beams dont work.....
    The problem is that after fitting the lights, I coded in the DRL's, which now work fine (Thats changing byte 02 from 40 to 10) and I also ATTEMPTED to change the code in Byte 00 from 69 to 26 but this code is not accepted bye the central electrics (09) controller. This means that the car keeps complaining about the lights, and whilst they work, I need them coding in properly so all of the bulb errors stop coming up.
    Does anyone have any clue as to why it will not accept this new code and does it mean that I need to possibly repalce the central electrics controller? I have a technik with all the goodies so I expect that it should be a high end controller anyway!
  1. A6 headlight upgrade
    By skidmarks in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-01-2011, 04:15 PM
  2. headlight upgrade
    By mike1640 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-09-2010, 10:44 AM
  3. HEADLIGHT PROBLEMS!! - one works, one does not.. HID's
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2009, 12:54 PM
  4. Headlight upgrade
    By JimC64 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-06-2009, 11:01 PM
  5. B5 Headlight upgrade
    By Derek Audi 1.8T in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-04-2008, 11:44 PM
