Thread: oil cooler replacement
  1. oil cooler replacement
    May 2008
    darlington
    hi, is the oil cooler on the 1.9tdi 130bhp awx engine the same as the 2.0tdi engines oil cooler ? they look identical.
    the cooler on my car has 2 pipes that face upwards, on the oil coolers that 2 motor factors and euro car parts have being trying to give me as a replacement has the 2 pipes that are situated sideways and would not fit my car.
    the only oil coolers i have seen advertised that look identical to mine are listed for the vag 2.0tdi engines !
    can someone help ???
  2. Re: oil cooler replacement
    Norfolk
    There are two different designs. You need the one with the pipes that matches yours. Your engine uses the more common one found on 1.9 and 2.0 diesels.
  3. Re: oil cooler replacement
    May 2008
    darlington
    this one looks identical to mine but it is advertised for the 2.0tdi engine only http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    it looks identical to mine, do you think it will fit ?
  4. Re: oil cooler replacement
    Norfolk
    It should fit as it fits most 1.9 and 2.0 pd tdi's.
  5. Re: oil cooler replacement
    May 2008
    darlington
    thanks, i have bought one.
  1. 2000 Beetle lights, alarms, oil!
    By bluebeetle in forum Beetle 2000-
    Last Post: 23-04-2008, 04:31 PM
  2. Answers from an oil expert...
    By oilman in forum Archive posts
    Last Post: 20-01-2008, 05:30 PM
