Thread: Bulb out alarm with LED light
Results 1 to 10 of 16
  1. Bulb out alarm with LED light
    Coventry
    This will apply to many vehicles across the VAG brand.
    I installed a reversing camera which replaces my nearside numberplate light. The unit provides a smaller built in numberplate light but this is LED and as such it has caused me to have a bulb out warning appear on the Dis.
    What electrical components do i have to wire in to get this warning to go away? Some sort of resistor? and do i put it on the positive or negative feed?
    Thanks in advance.
  2. Re: Bulb out alarm with LED light
    Norfolk
    You should have two wires. You put the resistor across the two wires as if it is a bulb you want to light. You want something like 30 ohm resistor but with a high power. At least 5 watts.
  3. Re: Bulb out alarm with LED light
    Coventry
    Cheers Martin.
    I will look at maplins for this.
    As it is the number plate light, I could solder it across the terminals behind the camera.
  4. Re: Bulb out alarm with LED light
    Coventry
  5. Re: Bulb out alarm with LED light
    Norfolk
    It explains here. https://sites.google.com/site/1810ma...lbs-and-lights what you need to do and why. The maplin resistors should be fine. Just pick a value near 30 ohms.
    You could try a 22 or 47 as they don't seem to do 30 ohm.
  6. Re: Bulb out alarm with LED light
    Coventry
    I bought a 47ohm 7w resister. It's a bit larger than I hoped but we will work with it.
  7. Re: Bulb out alarm with LED light
    Norfolk
    You don't want something too small. It will over heat.
  8. Re: Bulb out alarm with LED light
    Coventry
    I got this
  9. Re: Bulb out alarm with LED light
    Coventry
    Pleased to report that the resistor pictured above has solved the bulb out warning.
  10. Re: Bulb out alarm with LED light
    May 2010
    Devon England
    ideal, im getting the parts together to fit the reverse camera to my golf so i will need to do the same otherwise i will have an amber light on my dash
  1. Audi A4 Dashboard Instrument Panel Light Bulb Dash Light Fix
    By cbi004 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2011, 08:39 AM
  2. bulb out warning light
    By mbev51 in forum Golf MK5 - 2004 - 2009
    Last Post: 19-11-2010, 06:39 PM
  3. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  4. Alarm fault on a6
    By WAYNEO in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-04-2009, 10:10 PM
  5. Headlight Conversion How To??!!
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 10:57 PM
