Thread: Door entry light instal question
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 47
  1. Re: Door entry light instal question
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by g-black View Post
    ...... lock conformation beep and a big speedo read out on the MFD!
    Those two sound interesting - what size is the big speedo readout?
    1996 Laguna 2.2D
    1977 MGB roadster
  2. Re: Door entry light instal question
    Jan 2010
    Lisburn, United Kingdom
    Here is what I had when I tried to code the door.
    After reading alot into this, I've found that door modules changed in cars from 2007 onwards. The front door uses different pins, 18 and 19 apparenty as Martin already suggested, bit didn't seem to work for me. The big ground brown wire is in pin 21 but apparently there is a dedicated neg for the lights.
    As for the speedo, this is what it's like. Tried to set up a dial sweep on start up, but wouldn't give me that option!
  3. Re: Door entry light instal question
    Apr 2007
    France
    12 Post(s)
    I wonder if that speedo's possible on earlier cars?
    1996 Laguna 2.2D
    1977 MGB roadster
  4. Re: Door entry light instal question
    Norfolk
    0000757 should work. Is the code accepted ?
  5. Re: Door entry light instal question
    Jan 2010
    Think that's what we tried and it accepted it ok. Just tried every combination with the pins on the door and couldn't get it to light. Tested the bulb and wires on the cigarette lighter and worked fine!
  6. Re: Door entry light instal question
    Jan 2010
    Ok take 2 on this and still no joy. Coded all the doors so there now activated, but still can't get it to work. I tested pins with a 12v out and they worked fine, but as I tried to make contact with them, they cut the 12v off?! I have been testing with the door car of and the 32pin plug disconnected. Does everything have to be connected for it to work?
  7. Re: Door entry light instal question
    #17
    Norfolk
    I would wire the lights up with the battery disconnected. Reconnect the battery and see what happens.
  8. Re: Door entry light instal question
    #18
    Jan 2010
    Think I'm going to have to ask for the dealers assistance on this. I've searched the Internet for a diagram to show me what all the pins are for but haven't succeeded.
  9. Re: Door entry light instal question
    #19
    Feb 2010
    Louth Ireland....
    Have you found the pin which becomes live when you open the door ?
    Ex Passat B6 owner......to many retrofits to mention !
  10. Re: Door entry light instal question
    #20
    Jan 2010
    No. Any pins that were live with the door open remained live with the door closed! I will solder the negative wire into pin 21 which is the earth wire tomorrow. Then I'll try the positive in all the positions where there are pins, but no wires and plug it all in properly.
    Thought this would have been an easy mod but it's proving to be a headache!!
  1. HID Aftermarket kits - Not Legal....
    By RickT in forum Chat - Anything with wheels
    Last Post: 13-05-2011, 12:44 PM
  2. Replies: 4
    Last Post: 18-08-2009, 06:47 PM
  3. A4 engine management light .help
    By piggyA4 in forum Audi A4 - Archive Topics
    Last Post: 28-11-2007, 12:25 AM
  4. EMS Light intermittent - Air Mass Meter/breather pipe
    By tusken in forum Audi A3 - Archive Topics
    Last Post: 03-05-2007, 12:00 AM
  5. Custom A4, yeh baby
    By Maz in forum Audi A4 - Archive Topics
    Last Post: 09-03-2007, 06:13 PM
