Thread: help needed with reving engine on warm start up!!
  1. help needed with reving engine on warm start up!!
    Title says it all really
    Basically every time i i park up egt fuel papers etc, I come to start my passat TDI 115 pd and i get a reving engine and lots of black smoke 5-10 seconds of this and it decides to idle at 1100 rpm.
    So guy's and girls and ideas please
    Regards simon.
    P.S great forum people
    london/ UK
    Quote Originally Posted by printman View Post
    Regards simon.
    Changing Coolant Temp Sender ussualy helps...check if the temp gauge works, if it doesnt, its deffinatelly the CTS. If its not that, maybe low compression between the cylinders.
    Hi adamss24
    Many thanks for your advice I have taken the plunge and bought a Vag com unit and It was a temp sensor in engine managment.
    ATB Simon
    Hi Guys
    Sorry but any idea where the engine tempature sender is and a 115PD TDI engine. Is it the sensor mounted in the top hose at the back of the engine?
    Regards Simon
    Oct 2005
    Yup, should be either green or blue
    hi the only green or blue sensor i can find is mounted on the right hand lower hose to the radiator!! . the sensor on the top hose is black and screw mounted plug that plugs in is purple inside but i guess this is the water seal.
    part number on top sensor is Bosch 0281 002177/038 906 051.
    thanks simon
  1. A6 1.9 TDI Warm Start Judders!!
    By mrcheeezy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-11-2007, 03:10 PM
  2. Warm Start A4 Problem!!
    By orrinrob in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-11-2007, 10:58 PM
  3. Sharan TDI Warm start problem
    By timshaw in forum Touran - Sharan - Caravelle
    Last Post: 02-02-2007, 10:18 AM
  4. Passat X reg 1.8 petrol warm start problem
    By dtjvw in forum Passat - Archive Topics
    Last Post: 10-01-2007, 01:51 PM
  5. vw polo fails to start when just warm
    By rob kinna in forum New Member Introductions
    Last Post: 29-06-2006, 06:21 PM
