Thread: Mk4 gt tdi clutch grinding when clutch pressed half way
  1. Mk4 gt tdi clutch grinding when clutch pressed half way
    So i bought a GOLF MK4 GT TDI 100,000 Miles on the clock and its running nice until now.
    It idles fine but slightly noisier than it used to but when i press the clutch fully in it goes nice and quiet (or as quiet as a diesel can do).
    Just noticed now though that when i press the pedal half way down to the biting point without putting it in gear it makes a right racket that sound like dry bearings whirring around, but when my foot is all the way down it goes!?!?
    Just to compound things when i am driving along nicely i notice now that the gear stick vibrates sometimes like a BRRR ing noise.
    At the end of me tether anyone got any ideas???
    Think the clutch could be one problem but what else???
  2. Re: Mk4 gt tdi clutch grinding when clutch pressed half way
    Oh yes slight clutch judder when setting off which is why i think clutch / thrust release bearing
    TA
  3. Re: Mk4 gt tdi clutch grinding when clutch pressed half way
    May 2010
    Devon England
    hi mate it sounds very much like your dual mass flywheel needs replacing
  4. Re: Mk4 gt tdi clutch grinding when clutch pressed half way
    Thanks for the reply I was thinking that but do you think that would cause gear stick vibration? only seems to happen in 3rd or 4th or so it seems. Well of to see a recomended ex Vag guy tomorrow so we will see. Thanks again. Gareth
  5. Re: Mk4 gt tdi clutch grinding when clutch pressed half way
    Dec 2007
    Belfast
    Can you let me know how you get on with the vibrating gearstick please.
    I also have that aswell as excessive movement. ! Thought it was engine mountings but ave never had it investigated.
    Thanks.
  6. Re: Mk4 gt tdi clutch grinding when clutch pressed half way
    Well I took it to garage and all in all looks like DMF and the clutch. The car has a shake when ticking over caused by the flywheel and he thinks this is causing the gear stick vibration when driving. He is time served VAG engineer so will take his word for it. £560 plus VaT all in! Will let you know if it solves the gear stick wobble next Friday when it's done.
  1. MK4 1999 GT TDI Standard Suspension Kit
    By cantonamillor in forum Golf MK4 - 1999 - 2004
    Last Post: 20-11-2010, 11:13 PM
  2. The new bentley continental gt
    Last Post: 26-09-2010, 03:44 PM
  3. Tuned to **** 130 tdi best clutch (300+bhp)
    By chrissboro in forum Golf MK4 - 1999 - 2004
    Last Post: 30-12-2009, 12:47 AM
  4. PRICES OF NEW TOUAREG ANNOUNCED AHEAD OF MARCH LAUNCH
    Last Post: 02-01-2007, 08:22 PM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
