Thread: A4 Avant (53) - 1.8T Quattro : Electrical Faults...windows, interior lights, heater etc
  1. A4 Avant (53) - 1.8T Quattro : Electrical Faults...windows, interior lights, heater etc
    Jan 2011
    Barton-on-Sea, UK
    Hi All,
    After 7 years my A4 Avant 1.8T Quattro (53 Plate) has just let me down
    All the electric windows dont work, the interior lights stay on (unless manually switched off), the drivers wing mirror doesn't defrost, the heater doesn't chanel air to the windscreen, and the central locking seems to exclude the drivers door..... all which packed up 2 days ago.
    I'm a reasonably handy DIYer but definitely no mechanical/electrical expert. I have checked all the fuses and all are ok. Any ideas / suggestions as to what to try next.... or do I have to limp into Audi and part with my lifes savings ?
    Any help / advice would be greatly appreciated.
  2. Re: A4 Avant (53) - 1.8T Quattro : Electrical Faults...windows, interior lights, heater etc
    Jan 2009
    Birmingham
    36 Post(s)
    find someonw with vag com get the codes read on the car best place to start have you checked any relays?
  3. Re: A4 Avant (53) - 1.8T Quattro : Electrical Faults...windows, interior lights, heater etc
    Southern County Softy
    20 Post(s)
    check the passenger footwell for damp and lookaround the car battery for a puddle of water.
    The drains in the bulkhead can block causing water to get into the footweel.
    The CCM is under the pax seat, if this gets wet it can cause all sorts of electrical problems.
    As arman says, a code read is a good thing to have done.
    Look in the vagcom section for a member in your area..
    A4 2.5 tdi QS (mapped)
  4. Re: A4 Avant (53) - 1.8T Quattro : Electrical Faults...windows, interior lights, heater etc
    Jan 2011
    Barton-on-Sea, UK
    Hi Thanks for the quick responses.
    Have checked the inside of the car.... all appears very dry. Have checked round the battery (from what I can see) also dry. Haven't checked the relays.... wasn't sure where to start.
    Phoned my local diagnostic specialist, and they have suggested a £55+Vat test on Monday..... which IMHO seems ok, assuming I get an answer I can understand.
    Best regards,
    Mark
  1. Audi goes back to the future with commemorative quattro concept
    Last Post: 01-10-2010, 09:38 PM
  2. Replies: 0
    Last Post: 30-01-2008, 08:33 PM
  3. Tyres & Insurance
    By Sportingmac in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-01-2008, 05:59 PM
  4. New Audi A4 Cabriolet Range Update Bulletin
    Last Post: 09-11-2005, 08:37 PM
  5. Fast forward to spring with new A4 Cabriolet S line range
    Last Post: 02-02-2005, 09:26 PM
