Thread: Alloy wheel offset and PCD
  1. Alloy wheel offset and PCD
    Liverpool
    11 Post(s)
    I've just bought an A4 2.8 Quattro year 2000 model and want to change the std 16" alloys for something a little larger. Do you know what offset and PCD I should be shopping for? I've read on another post that new TT wheels wont fit, are there any sportier Audi's that alloys will go straight on? RS4, RS6 or RS8? If these will go straight on, would any year or do i need to look for alloys from a certain model?
    Many thanks in advance
  2. Re: Alloy wheel offset and PCD
    Dec 2007
    this forums a bit slooow !
    I believe - TT wont fit at all, but A4 & A6 will - so RS4's & RS6's will, I dont know about A8's
    I think its 45mm offset.
    Hope this helps & isnt 6 mths too late !
  3. Re: Alloy wheel offset and PCD
    Feb 2007
    UK (London)
    Ok you wil need 5x112 PCD with a Et35 offset but you have margins here.
    The RS4 wheels will not fit as they have a ET20 offset but the S4 rims will although you may need a spacer if you go with S4 b6 rims as I think they are ET45.
    04 Audi A4 B6 1.8TQ S-Line 190bhp 6 Speed Duel SMIC
    Milltek Exhaust|VMR boost Gauge|SP51 K04-15 Outlaw (K04-23+)|Samco Sport DV|034 Sport CAT|
    To be fitted: B7 RS4 F-Brakes|B5 RS4 R-Brakes|SB Stage4| TT MAF| 380 inj|
  4. Re: Alloy wheel offset and PCD
    Dec 2007
    what offset is / should be a standard a4 ?
  5. Re: Alloy wheel offset and PCD
    Feb 2007
    UK (London)
    Quote Originally Posted by Mothy View Post
    35
  6. Re: Alloy wheel offset and PCD
    Dec 2007
    & what range of offset can you get away with on a standard unlowered A4 ?
    Can you get away up to 45mm ? & is there a minimum ?
    thks
  7. Re: Alloy wheel offset and PCD
    Feb 2007
    UK (London)
    This may help you.
    Due to the overwhelming popularity of the "what offset are my wheels" threads, I think it's time we get something in the FAQ on this topic. Please constrain all offset/stock wheel questions to this thread so that we can have one source of info that will help the next person to come along with the question.
    Offset questions:
    Stock offset varies depending on the wheel you are talking about. So, depending on which wheel you have the answer will be different... please post the type of wheel you have (or think you have) if you want to know what offset you have.
    .... and no, et35 is not usually the answer.
    Wheel questions:
    If you have any other question about stock* wheels please post as much info as you know. Keep in mind that a year or other detail might be necessary for us to fully help you.
    *"Stock" wheels includes stock wheels from other Audi/VW years/models.
    Wheels for a4s are 5x112.
    TT/most vw wheels are 5x100, they will not fit.
    Offset Calculator:
    Just handy to have around as you try to fit aftermarket rims, or want to know your stance with various stock rims, so I've included this:
    http://www.1010tires.com/WheelOffsetCalculator.asp
  1. Golf MK4 alloy wheel size?
    By leemasiuk in forum Golf MK4 - 1999 - 2004
    Last Post: 07-02-2010, 09:55 PM
  2. Alloy wheel repairs on 1.8T Quattro
    By jb1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-10-2007, 10:12 PM
  3. alloy wheel cleaner
    By steveh in forum Archive posts
    Last Post: 07-03-2007, 09:21 AM
  4. ALLOY WHEEL 'UP-GRADE'
    By rottenronnie in forum Passat - Archive Topics
    Last Post: 06-09-2006, 11:37 AM
  5. Ronal alloy wheel problem
    By ajsphead in forum 100 - 200 - Turbo - 100 S4
    Last Post: 19-06-2006, 06:16 PM
