Thread: Condensation
  1. Condensation
    Dec 2010
    Bangor, Gwynedd, United Kingdom
    Does anyone have any suggestions to why there is a lot of condensation on my windows,i have felt the footwells for dampness but they seem ok,are there any common faults where i might be getting some dampness inside the car it's a Golf GT TDI 52 plate.Thank you
  2. Re: Condensation
    Southampton, UK.
    Something must be wet inside to give you all the condensation on the windows. The usual culprits are:
    • Blocked pollen filter drain
    • Blocked sunroof drains
    • Dodgy windows carrier plate seal
    See recent thread here.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 367,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
  3. Re: Condensation
    The pollen filter can be one reason
    Does the vehicle have AC? if so it can be the recirculation flap which is stuck closed
  4. Re: Condensation
    Dec 2010
    any suggestions on where i can find these faults
  5. Re: Condensation
    Southampton, UK.
    The pollen filter is under the n/s windscreen cowling and the drains are near the hinges of the front doors. Do a search in the Mk4 section and you'll find lots to read. Might be worth buying a Haynes manual. This will help you with finding & fixing lots too. Very handy to have it around.
  6. Re: Condensation
    is your rear windscreen washer working?....I had a nasty incident when frost popped a pipe out of its junction (above rear parcel shelf, inside the headlining) and water filled the rear quarter panel and poured through rear of headlining onto parcelshelf....lots of condensation....lots of bits to take out to put pipe back...mental note: ALWAYS use washer fluid with an antifreeze agent NEVER neat water.......
    PS if you take out the pollen filter and operate the recirculate button whilst looking down into where it was you will see the flap open and close....now you see the fan ....now you don't. If drain is blocked the pollen filter will be soaking!
    Drains on sunroof can become unconnected from their rubber exit grommets (the bit in the A post near the hinge) this lets water run down inside the windscreen pillar....another nightmare.......seems very hard freezing has been popping all sorts of pipes loose - so the word in the trade goes... good luck in finding your leak!
  1. Serious Roof Condensation Problem
    By sharan4me in forum Touran - Sharan - Caravelle
    Last Post: 08-01-2011, 02:47 PM
  2. Headlight Condensation Help
    By nick1974 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-03-2008, 11:04 AM
  3. Golf MkIV 1999 Condensation problem
    By Wump in forum Golf MK4 - 1999 - 2004
    Last Post: 15-01-2008, 10:14 AM
  4. Eos Internal condensation
    By Paul Hopkinson in forum Eos
    Last Post: 02-04-2007, 01:23 PM
  5. condensation inside screen
    By avantiblue in forum Audi A4 - Archive Topics
    Last Post: 23-12-2006, 12:09 AM
