Thread: Removing driveshaft retaining nut
Results 1 to 8 of 8
  1. Removing driveshaft retaining nut
    Jul 2007
    Co Durham
    What size socket is required to remove the driveshaft retaining nut on a Polo 1.2, 2002 please? Thanks
  2. Re: Removing driveshaft retaining nut
    Feb 2010
    basingstoke
    30mm mulipoint i think
  3. Re: Removing driveshaft retaining nut
    Jan 2009
    Quote Originally Posted by jimma04 View Post
    Mine was a 32mm the replacement nut from volkswagen is a big alan key think its 22mm if i remember correct.
  4. Re: Removing driveshaft retaining nut
    Jul 2007
    Co Durham
    Think mine is 32...its not 30mm, tried and failed with that size. Is it a standard multipoint socket?
  5. Re: Removing driveshaft retaining nut
    Jan 2009
    Just been out and pulled the wheel trip off its wait for it 36mm, biggest problem i had was not the nut but the shaft was seized in the hub, ended up round a mates with a big press to push the shaft out.
  6. Re: Removing driveshaft retaining nut
    134 Post(s)
    2019 Post(s)
    You must fit a new nut, they are 1 time only.
  7. Re: Removing driveshaft retaining nut
    Jul 2007
    Co Durham
    Minwes not 36...must be 35mm?
  8. Re: Removing driveshaft retaining nut
    134 Post(s)
    2019 Post(s)
    No, it is a definitely 12 point 36-mm but the socket needs to be thin wall and flat faced. I modified my old ¾” drive socket I used to use on Beetle rear hub nuts by grinding the face flush and grinding down the outside diameter until it fitted inside the hub centre. The VW tool number is T10125.
    http://www.toolbuddy.co.uk/36mm-12pt...t636-769-p.asp
  1. Replies: 10
    Last Post: 17-11-2015, 10:51 PM
  2. Rear Shock - How Do You Tighten The Retaining Nut???
    By James99 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-07-2009, 11:34 PM
  3. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  4. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  5. Please Help Removing crankshaft pully nut and stopping crankshaft moving
    By BobProperty in forum Golf MK3 - 1993 - 1999
    Last Post: 20-05-2009, 11:20 PM
