Thread: RCD 300 mp3 Radio Fault?
  1. RCD 300 mp3 Radio Fault?
    Oct 2010
    Kent. UK
    On the way to work this morning the radio decided to start scanning up the frequency range very slowly. If I pressed the button for the station I was on it went back fine, only to start scanning again about 10 mins later. Changed the station and it did it again! Same on the way home this evening.
    Does anyone have any ideas?
    It's in a 58 plate GT TDI Sport 140......
  2. Re: RCD 300 mp3 Radio Fault?
    May 2010
    Devon England
    sounds like it wasnt tuned in to a strong signal, or it could be a faulty connector, or even the weather, see if it carrys on over the next few days if it does then it may pay to get a scan as it will show up any faults with the radio
  3. Re: RCD 300 mp3 Radio Fault?
    Oct 2010
    Kent. UK
    OK. This has been doing this now for over a week. The car was scanned last week at the dealer and showed now faults. I had the unit out of the dash this morning and there are no loose connectors. I checked that the aerial was screwed up tight too!
    Any other ideas?
  4. Re: RCD 300 mp3 Radio Fault?
    Up North
    A 58 plate means you are still in warranty, unless you've done mega miles. Let the dealer sort it. Be very insistent and make sure you know how to duplicate the circumstances under which it faults. Sounds like a replacement radio to me.
    Make sure that even if there is supposedly no fault found, you get a warranty invoice/receipt from them that states the nature of the fault. That way you've got something to keep it alive, even if you're near the end of warranty.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  5. Re: RCD 300 mp3 Radio Fault?
    Oct 2010
    Kent. UK
    Quote Originally Posted by Teflon View Post
    Out of warranty I'm afraid; they aren't interested. Car has done nearly 66k! Possibly going to buy an RCD310 to replace it.....
  1. Please Help Fitted dis and cruise but having problems with coding etc
    By ukdan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-07-2010, 06:45 PM
  2. Rcd 300/ rcd 300 mp3 ???
    By lezzer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2010, 11:21 AM
  3. Integral Bluetooth radio for A4
    By Gary M in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-03-2010, 03:45 PM
  4. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  5. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
