Thread: A2 rough idle + no throttle after rebuild
  1. A2 rough idle + no throttle after rebuild
    Aug 2007
    Oxfordshire
    Hello all,
    Would love to hear if anybody experience with the following and can offer any suggestions (I am new to this vehicle and VAG COM)?
    Engine = 1.4 Petrol - Code AUA
    Chassis Type: 8Z - Audi A2
    Scan: 01 02 03 08 15 16 17 37 45 46 56 57 75 76 77
    VIN Number: WAUZZZ8Z02N036715
    HISTORY:
    - Crank sprocket slipped on the cambelt due to ice formation filling in the tooth profiles => 8 x intake valves bent => no other damage => so, new valves fitted and lightly lapped = > head rebuilt with new gaskets.
    - Engine started on the first turn of the key and sounded good for the first 30s or so on the rich startup map => I gently blipped the throttle and the revs rose to 2500rpm => on return to the idle position the engine was now running roughly, with a lumpy hunting idle.
    - Fault code scan revealed the following:
    Address 01: Engine
    Part No: 036 906 034 Q
    Component: MARELLI 4LV 3415
    Coding: 00051
    Shop #: WSC 00579
    WAUZZZ8Z02N036715 AUZ7Z0B2061291
    1 Fault Found
    17961 - BAROMETRIC/ MANIFOLD PRESSURE SIGNALS – IMPLAUSIBLE CORRELATION
    P1553 – 350C
    Readiness: 1110 0101
    - So I checked the following:
    o Air leaks – Nothing visible (difficult to say for sure) Can anyone recommend a suitable test procedure?
    o Cycling through test functions – each part appeared to respond
    o Cam timing re-checked, case I’d messed up => all correct
    o Compression test = 12bar across all cylinders (test carried out at around 30°C water temp, ECU fuel P fuse removed, foot on the accelerator. I’m not sure how the electronic throttle responds in this condition… anyone?
    - No further forward, I decided to check the live data blocks:
    o IGNITION ON (revs=0rpm) (MAP=999mb) (Throttle=7.5°) (Ignition=0°)
    o ENGINE IDLING (revs=1275rpm) (MAP=675mb) (Throttle=7.4°) (Ignition=0°)
    o ENGINE RUNNING + THROTTLE BLIP (revs=1275rpm) (MAP=690mb) (Throttle=7.4°) (Ignition=+/-4°)
    - Points to note from live test
    o Throttle angle pretty much constant throughout all three tests
    o The MAP values seem too high (as expected with the fault code), manual states values should be between 240 and 420mb
    o When blipping the throttle, the revs rise only very slightly and the ignition angle is the only parameter that appears to change in response.
    - My next thought was to try and clean the TB and perform a re-align.
    Thanks in advance
    Jonny
  2. Re: A2 rough idle + no throttle after rebuild
    131 Post(s)
    1979 Post(s)
    Could be the throttle body. It is a 2002 with an AUA engine for anyone who wants to know.
  3. Re: A2 rough idle + no throttle after rebuild
    Check intake manifold pressure sender
    Check intake system for leaks (unmetered air)
    Check exhaust gas recirculation system:
    Check throttle valve control part
    Check activated charcoal filter solenoid valve
    Try and generate the readiness code,this might show up what is wrong
  4. Re: A2 rough idle + no throttle after rebuild
    Aug 2007
    Oxfordshire
    Hi Crasher, yes it is.
    -> the throttle body appears to cycle fine when prompted.
    Hi kenny,
    Tried all of the your points, the only one I'm not confident about is the un-metered air.
    Update: i have just sprayed some brake cleaner at the intake manifold with the engine runing - the revs fluctuated!
    I'm about to take the inlet manifold off, hoping to find a kinked or missing seal - wish me luck.
  5. Re: A2 rough idle + no throttle after rebuild
    131 Post(s)
    1979 Post(s)
    I had one earlier today with the same fault code and problem on a 1.6 BCB engine (very similar) and the reason was a leak on the servo feed pipe. Even though the TB looks OK, I would still clean and reset it.
  6. Re: A2 rough idle + no throttle after rebuild ***Now Fixed***
    Aug 2007
    Oxfordshire
    Update 2 - Problem Solved - Kinked rubber seal on intake manifold port 4, I must have caught it lowering the head onto the block (see attached image).
    Engine now runs sweet as a nut.
    Massive sigh of relief.
    Thanks for your help guys.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Please Help 2005 2.0 TDi PD sportline
    By AUDICAB99 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-12-2009, 08:29 PM
  3. 1998 B5 - Hunting Idle after Throttle Body Cleaning
    By ectwo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2008, 05:53 AM
  4. Tune Weber carb (not type specific)
    By bishbosh66 in forum Volkswagen
    Last Post: 30-01-2008, 11:34 AM
  5. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
