Thread: A4 B7 S line Avant Quattro Tyre Scrub..
Results 1 to 10 of 16
  1. A4 B7 S line Avant Quattro Tyre Scrub..
    Feb 2010
    Ross Herefordshire
    Hi all, I've noticed a tyre scrub from the n/s/f when on full lock left. No prob when on full lock to the right though. I've had it laser aligned, well checked they said there was nothing out to adjust. It does have one odd tyre on that side, a Dunlop asymetric, the rest are p zero's. (it's done 110k now, not expecting suspension issue though)
    Any Ideas???
    Cheers!
  2. Re: A4 B7 S line Avant Quattro Tyre Scrub..
    Aug 2009
    Near Lanark
    21 Post(s)
    What size are the tyres?
    As far as I know, anything wider than 235 will rub without spacers.
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  3. Re: A4 B7 S line Avant Quattro Tyre Scrub..
    Feb 2010
    staffordshire
    How does it drive , does it pull under braking?
    Where did you have it checked .
    Full vcds HEX-USB-CAN Interface available in the staffordshire area PM me
  4. Re: A4 B7 S line Avant Quattro Tyre Scrub..
    Jan 2010
    kent, england
    10 Post(s)
    Sounds like it may be the old Quattro rumble, do the tyres need changing?
  5. Re: A4 B7 S line Avant Quattro Tyre Scrub..
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    As above , a quattro thing ,but gets worse,or more pronounced as tyres get lower.
    Had the same on A4 3.0 quattro tiptronic sport
  6. Re: A4 B7 S line Avant Quattro Tyre Scrub..
    Feb 2010
    Ross Herefordshire
    Thanks guys, the tyres are 235, and not worn down yet, plenty left actually, but the n/s/f is s different brand and asy so that maybe causing the noise, seems a shame to replace decent tyre thats not worn out??
  7. Re: A4 B7 S line Avant Quattro Tyre Scrub..
    Feb 2010
    Ross Herefordshire
    RMH1, I was getting a pucture repaired and they said they'd check it for free, was laser but not audi. It did show that the two axles are parallel, not what I had expected to see. Audi main dealers want £140 to check it, bit steep if its all ok.
  8. Re: A4 B7 S line Avant Quattro Tyre Scrub..
    Oct 2009
    10 Post(s)
    Do yourself a favour for no cost.
    Try moving the rims around the car, i.e,that n/s/f onto the rear if the feeling goes it may save the tyre and cure your rumbling
  9. Re: A4 B7 S line Avant Quattro Tyre Scrub..
    Dec 2006
    This is normal for a quattro and nothing to worry about. I have heard some people refer to it as 'Quattro push' All my Audi cars have done this, as do my my friends 'Torsen' quattros. A TT or A3 shouldn't do it, due to it having a totally different system.
    Basically whats happening is the front tyres are losing grip due to the car being pushed from the straight rear wheels and pulled from fronts on full lock.
    Generally the lower profile the tyre and bigger the rim the worse it is. Three weeks ago my car did it so bad even my girlfriend asked if there was something wrong with it!!
    New set of tyres and the problem went away... it will come back when the tread gets down to about 3mm...
    Dunlop tyres, in my experience, are utterly rubbish. When I bought my car it had a full set of brand new Dunlops on it! The quattro push was terrible and the car was unsafe when pushed to it's limits and beyond... I was so unimpressed with them I bought a whole new set of four Goodyears just to get the awful Dunlops off! It was like the car had become twice as nice to drive!
  10. Re: A4 B7 S line Avant Quattro Tyre Scrub..
    Feb 2010
    Ross Herefordshire
    Thanks for that guys, it's such a shame, but if it's normal so be it, the quattro did make a difference in the snow so has already earnt its wages, plus its a great looking car. I'm looking at the fuel inj thread, not good news at all.
  1. About to purchase A4 2.0TDI 170PS Avant B7
    By sanstorm999 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-01-2010, 02:54 PM
  2. AUDI S6 QUATTRO RELEASED FOR UK ORDERING
    Last Post: 14-03-2006, 09:10 PM
  3. Replies: 0
    Last Post: 05-03-2006, 07:58 PM
  4. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
  5. New Sporting Audi A6 S Line models arrive in britain
    Last Post: 15-07-2004, 09:40 PM
